Please Verify my MBC hookup
Old Apr 5, 2003 | 06:31 AM
LshatchTurbo's Avatar
New User
Default Please Verify my MBC hookup
I just wanted you guys to look at the way I hooked up my MBC. ITs the air regulator type (From lowes) and seems to work awesome, no boost spikes. The question i have is, at lower engine loads, say before the car actually goes into boost, when my BOV goes off it flutters. At full boost and a gear shift, the BOV sounds fine. I messed around with the adjustment on the Greddy Type-S, but the fluttering at lower engine loads seems to still be there.
Is this because of the nature of the air regulator type MBC, or is my MBC not correctly hooked up?
[Modified by lshatchturbo, 11:05 AM 4/5/2003]
Old Apr 5, 2003 | 06:33 AM
Mr. Softee's Avatar
Default Re: Please Verify my MBC hookup (lshatchturbo)
your img doesnt work. im thinking you BOV is fluttering becase you arent pushing enough boost when you blow off
Old Apr 5, 2003 | 06:40 AM
New User
Default Re: Please Verify my MBC hookup (94goldjungsr)
Weird cause I can see the pic? Hmm..anyways this is my first time using the a MBC. Before I could hit the BOV without going into boost and it was sound fine, now it flutters in non boost. Just wanted to make sure everything was fine
Old Apr 5, 2003 | 07:29 AM
evoeone's Avatar
i would run the wastegate boost line from the turbo, it will maybe work better. the fluttering is at low boost,
Old Apr 5, 2003 | 07:51 AM
New User
Default Re: Please Verify my MBC hookup (evoeone)
I would have def. went that route, but the housing did not come tapped with a fitting. Its not fluttering at low boost, more like lower loads.
Jayboy
May 12, 2005 10:57 PM
jBj
Mar 14, 2005 10:37 AM
rusteds2k
Jan 7, 2004 09:33 AM
DamonBoost
Jun 4, 2003 08:36 PM
PUREVIL
May 20, 2003 09:13 PM
