Civic radiator in the Teg to make room 4 turbo, mounting problems!!
When I instaleld my turbo I had to remove my stock Teg radiator and swap it for a civic radiator. Obviously the little bump stops on the bottom of the radiator do not match up with the stock integra therefor the radiator is just hanging loose on one side and I had to fabricate shitty brackets to hold it in place (see pic) .
My question is this, I'm about to buy a high quality radiator and I was wondering if anyone make one thats civic size but will fit into the stock brackets or does anyone make some sort of adapter kit?? I'm tired of the ghetto brackets. Thanks guys!
Re: Civic radiator in the Teg to make room 4 turbo, mounting problems!! (Diego Boost)
talk to tony1 on here he can weld some nice aluminum brackets for you that will look alot better...
You need the civic top bracket that wounts the radiator to the upper support.
I htink that you can get Spoon ones....but break out the KY, hehe.
Re: Civic radiator in the Teg to make room 4 turbo, mounting problems!! (93LSivic)
contact http://www.jimfab.com I bet he might have a kit or be able to make you something real nice as he just did this to his own daily driver.
