injector help , o-ring?
Old Jul 7, 2003 | 12:51 PM
r7's Avatar
r7
Default injector help , o-ring?
550cc peak and hold injectors, do they install just as shown? or?
do i need a o-ring on the top side?
pictures @
http://members.shaw.ca/rseven/injectors/
Old Jul 7, 2003 | 02:31 PM
MiraiZ's Avatar
Default Re: injector help , o-ring? (r7)
You should get new o-rings and bottom seals....leaking gas on a hot engine does not make a good combo...better safe than sorry
Old Jul 7, 2003 | 04:36 PM
r7's Avatar
r7
Default Re: injector help , o-ring? (MiraiZ)
so i am missing something there? or?
anyone?
Modified by r7 at 4:50 AM 7/8/2003
Old Jul 7, 2003 | 11:10 PM
r7's Avatar
r7
ttt
Old Jul 7, 2003 | 11:14 PM
Kwuaymaikrup's Avatar
Ahhh...Siemen 76lbers??? Ypu need to take the O-ring and the fuel rail to the hardware store and test fit O-rings until you have the right one. I just used the O-rings from my stock injectors....make sure it is a very tight fit. I use a bit of oil to get it to fit into the rail. HTH
-Ryan
Old Jul 7, 2003 | 11:28 PM
r7's Avatar
r7
Default Re: injector help , o-ring? (Kwuaymaikrup)
yeah, are they good injectors?
is 76lbs = 550cc?
Old Jul 7, 2003 | 11:38 PM
I Like Boost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r7 &raquo;</TD></TR><TR><TD CLASS="quote">yeah, are they good injectors?
is 76lbs = 550cc?</TD></TR></TABLE>
76lbs = almost 800cc
Old Jul 8, 2003 | 10:59 AM
r7's Avatar
r7
Default Re: injector help , o-ring? (IMPULSE B18C-T)
how can you tell the size by looking @ the injector?
Old Jul 8, 2003 | 04:20 PM
Racerboy03's Avatar
Anybody know where i can find some RC 550 O-rings? Or will stock ones work fine?
Old Jul 8, 2003 | 04:33 PM
MiraiZ's Avatar
Default Re: injector help , o-ring? (Racerboy03)
stocko should be ok...may need some boring...otherwise go to http://www.rceng.com e-mail customer service...they're pretty good there...got mine in 5 days and I live in Japan
Old Jul 9, 2003 | 02:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r7 &raquo;</TD></TR><TR><TD CLASS="quote">how can you tell the size by looking @ the injector?</TD></TR></TABLE>
By the number on the side.....and another thing...you are going to need to have them machined to fit inside your rail. Either that or you will need to drill out the rail. Good luck
-Ryan
Old Jul 9, 2003 | 11:17 AM
r7's Avatar
r7
and how can i tell what the # mean
Old Jul 9, 2003 | 01:40 PM
r7's Avatar
r7
i have an aem rail, they fit in, but, can i use the stock injector o-rings?
BOOSTED_JDM_DB8
May 15, 2006 07:07 PM
PnkRokCountryboy
Apr 13, 2006 02:45 PM
SlowB16si
Mar 13, 2006 11:46 AM
SpdFrk
Dec 17, 2003 08:07 AM
