OT: Been practicing with the welder
Old Jul 6, 2003 | 09:41 PM
Sonny's Avatar
Default OT: Been practicing with the welder
Guess what kind it is?
I bought a DIY exhaust kit from Mike (KTeller8 ) and have been practicing on muffler shop scraps. I don't get much garage time these days, so I've been trying to do 2-3 weld joints per night. I've got about 5 nights of practice so far.
Any tips?
Sonny
Old Jul 6, 2003 | 09:46 PM
intekragsr's Avatar
lookin good. what kinda welder do you have?
Old Jul 6, 2003 | 09:49 PM
lazerus's Avatar
Default Re: (intekragsr)
stick or tig.. something like that :-)
Old Jul 6, 2003 | 09:55 PM
stierhund's Avatar
Default Re: OT: Been practicing with the welder (Sonny)
Would be nice to know exactly what kinda welder you used because it looks like you need to go up on the voltage and down on the feed speed if you have a standard mig welder. My .02 (I have a miller mig welder)
Old Jul 6, 2003 | 09:57 PM
Sonny's Avatar
I'm using an oxy/acetylene gas welder.
#0 tip
4 psi of acetylene
8 psi of oxygen
1/16" filler rod
I've been experimenting with various types of flames. The really hot flame seems to work best as getting a good weld, but it is also the easiest to burn holes with.
Sonny
Old Jul 6, 2003 | 10:16 PM
boosted_zc's Avatar
I think they look pretty damn spiffy. They definately look better than my mig welds. I shoulda got a tig, argh.
Old Jul 7, 2003 | 08:19 AM
Sonny's Avatar
I wish I had done a little more research on this before I started. This aluminized muffler piping sucks.
I was always told that welding stainless steel with a gas torch was not possible. Richard Finch's "Welding Handbook" states that it is possible for small thicknesses of metal, but even then, the weld is prone to contamination.
I found a site that sells flux for use with stainless steel gas welding. It's cheap, too. Oh well, live and learn.
Sonny
Old Jul 7, 2003 | 08:58 AM
DownBoyDown's Avatar
Wow, those welds are really great. OxyAcetylene welding is really tricky. Very good for only 5 nights experience.
Old Jul 7, 2003 | 09:34 AM
mos's Avatar
mos
Default Re: (DownBoyDown)
Looks good!
Gas welding is more similar to TIG welding than MIG or ARC in how you do it, so after you get your TIG setup your gas experience can carry over a little.
Old Jul 7, 2003 | 10:30 AM
Sleepin''s Avatar
Nice! That looks a hell of a lot better than the guy who just welded up my new muffler.
Old Jul 7, 2003 | 11:09 AM
jarel's Avatar
Default Re: OT: Been practicing with the welder (Sleepin')
For all you welder people......what is TIG and MIG and what is the difference???
thanks for the help....this question has been bugging me for a long time.
Old Jul 7, 2003 | 12:51 PM
LshatchTurbo's Avatar
New User
Default Re: OT: Been practicing with the welder (chyknees)
wow Sonny, looks like u might be good at something after all
<-- cant weld worth a damn
Old Jul 7, 2003 | 01:03 PM
Ivan's Avatar
senior gold member
I've been reading up on welding too. seems like I can weld aluminum and SS on my mig. all I have to do is get the correct mix of gas and the proper wire and thats it.
Old Jul 7, 2003 | 01:49 PM
Sonny's Avatar
Default Re: OT: Been practicing with the welder (lshatchturbo)
Remy,
I can only hope to someday be as cool as you.
Sonny
Old Jul 7, 2003 | 02:03 PM
stierhund's Avatar
Default Re: (Sonny)
Welding stainless is easy, but if you plan to weld somethin together that will take high heat over a long period of time dont do it. Stainless has a different expansion rate under heat than even stainless welding wire. Use mild steal and ceramic coat it or find a local shop that does top notch coatings for a good price (ie normal ceramic coloring, ceramachrome, chrome, etc.)
A lot of people are using stainless on turbo manifolds... sorry but that is a huge mistake for longterm life of a manifold.
For people that are new to welding...
MIG is a linefed to gun welder that supplies DC voltage and gas at the same time through a nozzle that you just point and feed to the metal
TIG is the same premise but you can find many different setups that allow you to flow the gas seperately and get really smooth strong welds that are way superior to MIG and also include flux cored metal wires that will pull heat to the metal faster
Old Jul 7, 2003 | 02:05 PM
stierhund's Avatar
Default Re: OT: Been practicing with the welder (Ivan)
Ivan, get 35 gauge aluminum wire, and a tank w/100% argon gas, make sure to clean the gun feed wire, and change your tip if you dont have 35 gauge already
Also get a tweeko gun
Old Jul 7, 2003 | 02:09 PM
Ivan's Avatar
senior gold member
Default Re: OT: Been practicing with the welder (stierhund)
good info
EF9_TryMe
Welding / Fabrication
Feb 5, 2012 06:08 PM
blackeg
42
May 25, 2007 06:59 PM
RMF
92
Jun 14, 2006 05:34 PM
FeatherWeight
14
Nov 10, 2004 11:16 AM
Greyout
Apr 24, 2002 06:20 AM
