what went wrong?
Old Jul 8, 2003 | 07:20 AM
Dorikamu's Avatar
Default what went wrong?
This is a darton stage 2.
Old Jul 8, 2003 | 07:32 AM
Jared's Avatar
Default Re: what went wrong? (Dorikamu)
Looks like the liner wasn't bored properly to accept the sleeve.
Old Jul 8, 2003 | 07:33 AM
DC2R714's Avatar
more details?
Old Jul 8, 2003 | 07:35 AM
Muckman's Avatar
Moderator in Chief
Howcome there's no heads on those head bolts? They must not be OEM?
Old Jul 8, 2003 | 07:45 AM
Dorikamu's Avatar
The block was freshly built. I ran the engine for about 1000 miles to break it in. The outter sleeve cracked the first time I ran 8lbs of boost (during tuning with hondata). There was no sign of denotation shown on the head or the piston. This darton stage 2 suppose to hold 20+lbs of boost???
Old Jul 8, 2003 | 10:01 AM
DC2R714's Avatar
Where was the block done? Sounds like installation error.
Old Jul 8, 2003 | 10:09 AM
Dorikamu's Avatar
Default Re: what went wrong? (DC2R714)
Can you elaborate on what are the possible installation error?
Old Jul 8, 2003 | 10:16 AM
DC2R714's Avatar
Sounds like the clearances might have been off when installed and if your sleeves warped during those 1000 miles it could have broke apart the sleeve.
Old Jul 8, 2003 | 11:25 AM
Dorikamu's Avatar
I am sorry, what clearances are you talkin about here?
Any help is appreciated.
Old Jul 8, 2003 | 11:34 AM
Farnsrocket's Avatar
Your bearing clearances.
Old Jul 8, 2003 | 11:55 AM
hulkhb's Avatar
Default Re: what went wrong? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Howcome there's no heads on those head bolts? They must not be OEM?</TD></TR></TABLE>
those are called head studs, like arp.
Old Jul 8, 2003 | 12:27 PM
Dorikamu's Avatar
Default Re: what went wrong? (Farnsrocket)
err.. I dont believe is it a bearing issue.. if you do think so, maybe you can explain why???
Old Jul 8, 2003 | 01:46 PM
Joseph Davis's Avatar
You notice the aluminum bore the ductile iron liner slides inside of? The broken part? That clearance, the manner of insertion by the machine shop, etc, something like that.
Old Jul 8, 2003 | 02:14 PM
Dorikamu's Avatar
Default Re: what went wrong? (J. Davis)
you mean the cracked outter sleeve (aluminum bore) is caused by a bearing clearance problem?
how does that work?
These are the possible things that can do the damage, I was told.
- The head gasket was not sealed rite
- The sleeve slipped
What do you guys think?
superjet
Jul 30, 2012 10:08 PM
CANTFAZZDISCHIT
Jul 9, 2004 07:18 PM
Allstar
Jun 29, 2004 05:54 PM
Kwuaymaikrup
Nov 3, 2003 08:10 PM
00SIBOOST
Feb 28, 2003 09:47 AM
