Endyn catch can install question
Old Jul 6, 2003 | 01:11 PM
Batoutahell's Avatar
Default Endyn catch can install question
I am following the "off road" installation instructions. I am supposed to tee the 3/8" drain hose from the bottom of can into 1/2" hose that goes from the bottom "bung" of the can to the driver's side plug. The way I have the catch can mounted, it would be MUCH easier if I could tee into the other 1/2" line, the one that runs from the top "bung" of the can to the passenger's side plug. Is this alright to do?
Old Jul 6, 2003 | 01:28 PM
CRVRX's Avatar
Default Re: Endyn catch can install question (Batoutahell)
You can "T" it into either 1/2" line, Just make sure the can is higher than the drain. It will drain OK, I have installed them both ways.
Old Jul 6, 2003 | 01:39 PM
Default Re: Endyn catch can install question (CRVRX)
Thank you, my life is much simpler that way.
turboHondaWesJ
Dec 22, 2012 07:44 AM
ImaHondaLover
Mar 20, 2008 03:32 AM
vinuneuro
Jul 15, 2006 07:23 PM
prayludin
Mar 30, 2005 12:03 PM
tegedrex
Aug 24, 2004 05:17 AM
