fuel pressure regulator
Old Jul 7, 2003 | 07:34 AM
phthalo's Avatar
GDD4LIFE
Default fuel pressure regulator
do you have to run your aftermarket fpr through your stock one or do you just replace it?
Old Jul 7, 2003 | 07:37 AM
96IntegraRS's Avatar
Default Re: fuel pressure regulator (phthalo)
You replace it, or in the case of the B&M, modify it.
What's your setup?
Old Jul 7, 2003 | 07:43 AM
phthalo's Avatar
GDD4LIFE
how do you modify it?
Old Jul 7, 2003 | 08:07 AM
phthalo's Avatar
GDD4LIFE
anyone?????
Old Jul 7, 2003 | 09:14 AM
Pengo's Avatar
Default Re: (phthalo)
fprs like aem, sx, and aeromotive completely replace the stock unit. the b&m is used by chopping off the top of your stock fpr and replacing it with the b&m piece. this allow you to turn up the fuel pressure. the downsides are that you can't lower pressure below stock and it doesnt have the options of changeable fuel return orifices like some of the others
Old Jul 7, 2003 | 04:48 PM
Default Re: (Pengo)
Again - what is your setup.... if you tell us we can help you, and determine if you need the adjustable regulator.
Old Jul 7, 2003 | 05:05 PM
Burke's Avatar
Banned
Default Re: (96IntegraRS)
http://theoldone.com/articles/regulator/
check this, drillijng a hole......
Old Jul 7, 2003 | 07:40 PM
Pengo's Avatar
Default Re: (Burke)
the fuel pressure relief mod works but i wouldnt recommend it unless ur desperate. it makes starting up the car a real bitch. gotta prime the pump so many times just to build up pressure to start, it gets annoying. esp if you have electronics that are powered with the ignition
Old Jul 8, 2003 | 11:29 AM
phthalo's Avatar
GDD4LIFE
i'm installing the sohc greddy turbo for the d16 with stock internals, dsm injectors but can seem to get the car running good at all.......pretty sure it's the fuel pressure for the injectors.
Old Jul 8, 2003 | 12:16 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phthalo &raquo;</TD></TR><TR><TD CLASS="quote">i'm installing the sohc greddy turbo for the d16 with stock internals, dsm injectors but can seem to get the car running good at all.......pretty sure it's the fuel pressure for the injectors.</TD></TR></TABLE>
You need something to control the injectors like Hondata or the SAFC. Otherwise, it will run like doggy doo as you are finding out.
Old Jul 8, 2003 | 05:54 PM
phthalo's Avatar
GDD4LIFE
Default Re: (ladysman)
that's what my brother keeps telling me.........but should i even bother with the regulator
Old Jul 8, 2003 | 07:58 PM
ScrapinSi's Avatar
you HAVE to tell the computer to cut down the fuel either with a chip, hondata, or an AFC... You have to remember... Your computer thinks you have a stock injector in there... think of that as a garden hose... So therefore the ECU is gonna say "Ok, run the injectors at 80%"... Now you put in dsm injectors, which in relation to the garden hose is like a fire hose... But the ECU is still saying "Run the injectors at 80%" so therefore, your DUMPING too much fuel... Be careful, you can wash out the cylinders and screw up your rings...
Old Jul 9, 2003 | 06:58 AM
phthalo's Avatar
GDD4LIFE
thanks that just explained everything......................i think i'm going with the hondata but i don't really understand ecu's that much............how do you program them to the specs you need
Modified by phthalo at 4:21 PM 7/9/2003
h22 ac
Aug 13, 2006 01:48 PM
Niskyspy
Mar 4, 2006 03:30 PM
Bad-T
Jun 14, 2005 09:57 AM
ProjectCRXtacy
Jul 15, 2003 03:20 PM
JMX
Mar 15, 2002 09:53 AM
