TD04H-15G on an LS?
Old Jul 5, 2003 | 05:15 PM
rubens's Avatar
Default TD04H-15G on an LS?
I found a "TD04H-15G" kit for pretty cheap, new..
How would I make this fit on an LS? I know some manifold(s) need to be changed..what's the deal with using this kit on the LS?
Rubens
Old Jul 7, 2003 | 01:21 PM
rubens's Avatar
Default Re: TD04H-15G on an LS? (rubens)
Old Jul 7, 2003 | 01:22 PM
rubens's Avatar
i KNOW there are people using this kit!
Old Jul 7, 2003 | 01:24 PM
kpt4321's Avatar
You didn't tell us what car the kit is designed for, or what parts it comes with.
Old Jul 7, 2003 | 02:08 PM
imonkie's Avatar
i know that HKS used to make a manifold that you can mount a 15g on. i'm not sure if the 18g mani's can mount a 15g
-ivan
Old Jul 7, 2003 | 03:22 PM
boostsohfast's Avatar
Default Re: TD04H-15G on an LS? (imonkie)
If what you are talking about is a greddy kit, then you can get the greddy b-series manifold and bolt the 15g turbo up to that. But that would be a waste of money since the only part of the kit you would use is the turbo and possibly some piping. Specify what you are talking about.
Old Jul 7, 2003 | 04:40 PM
InTeGrA B18b1's Avatar
Default Re: TD04H-15G on an LS? (boostsohfast)
you ll get some fast spool but you will be SLOWWWWWWW
Old Jul 7, 2003 | 05:03 PM
Joseph Davis's Avatar
Default Re: TD04H-15G on an LS? (InTeGrA B18b1)
I infer that he's talking about the 92-95 Greddy SOHC turbo kit, fitted to an LS engine. That turbo manifold will bolt to the LS head with some small amount of porting and ovulating bolt holes. It's been done quite a bit.
And InTeGrA B18b1 is quite right, an Integra LS with that turbo is SLOWWWWWWW. The best I've heard out of one was turning a 12.9 on slicks at 12 psi. Pathetic.
Old Jul 7, 2003 | 06:14 PM
Default Re: TD04H-15G on an LS? (J. Davis)
funny how direp has a better turbo and setup and barely gets a 12.8. i guess that turbo must have mad top end huh davis.
Old Jul 7, 2003 | 06:54 PM
Happyman's Avatar
A 15G is pretty small. The others are right, it won't carry max boost all the way to your redline in my guess. ANd I think the turbo is only good for like 250-275 hp which in a teg will barely get you to mid 12s
Old Jul 7, 2003 | 07:23 PM
rubens's Avatar
Default Re: TD04H-15G on an LS? (Happyman)
Yes, I'm talking about the GReddy kit on the LS.
I'm not looking for anything crazy..around a 13.9-14.2? I think that's doable isnt it?
Old Jul 7, 2003 | 07:24 PM
rubens's Avatar
yup, sohc 92-95 kit on the ls.
Old Jul 7, 2003 | 10:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InTeGrA B18b1 &raquo;</TD></TR><TR><TD CLASS="quote">funny how direp has a better turbo and setup and barely gets a 12.8. i guess that turbo must have mad top end huh davis.</TD></TR></TABLE>
Well, FuCkTaRd, the dyno chart I saw of the full kit (with IC) at 5.5 psi made 180 whp and 200 wtq. Power visibly dropped past 6 grand, but it drops like a stone past 6.5 grand on a stock LS head/cams anyway, big ******* deal. Top end has nothing to do with it.
The 12.9 second DA I'm talking about was a goodly number of years ago, probably before you moved out of mommy and daddy's house. Children who comment based on zero experience, even second hand experience, should take the gentle rebuke they recieve the first time instead of the full spanking that comes after they talk back.
Old Jul 7, 2003 | 11:39 PM
integrx's Avatar
New User
get it if its a deal.
Integra_RS
Jun 11, 2006 07:06 AM
JAI-DM
Dec 20, 2003 11:33 AM
98cwitr
Feb 8, 2003 09:29 PM
IntegraBoi
Jul 12, 2002 11:02 PM
SoSoJeff
Jun 22, 2002 12:30 PM
