will a 57trim make 450whp
I'd like to see proof of the 57 trim making 450whp.
The 57 trim will make 450whp level only if other aspects of the turbocharging system have been modified such as an equal length manifold, 3" downpipe and exhaust, larger intake manifold, headwork, and most importantly exhaust housing size. Another huge factor is displacement of the engine the 57 trim is going to be used on. The 57 trim will support around 400whp nicely, but without alot more modifications to the overall system power production will not be there.
the guy asked if the turbo would make 450hp. He did not ask if it would make 450hp with a equallegnth manifold or larger intake manifold or head work. I can show you a dyno sheet from Trackmaster motorsport 10.60 civic H/B which made 420hp at about 20psi. just built bottom end with cast turbo manifold, 2.5 AC compataible DP, and no sheet metal intake manifold.This is a daily driver street car with full interior and the kid supposely works at REVHARD MFG..If you like call them at 661-254-6055
Tim McGimpsey from BASZ Racing in Cincinnati, OH made 516.7whp on a slightly modified Drag 3 kit on a built GSR. Im almost certain it was a 57 BUT could have been a 60 trim.
Its been a while.. that setup was last years.
wade
Sep 18, 2011 08:11 PM
gawath
Dec 15, 2006 10:02 AM
done
Oct 3, 2005 08:06 AM
