Ok i've never pulled a head, just a simple question..
Old Jul 8, 2003 | 08:48 AM
Integra_Boi's Avatar
New User
Default Ok i've never pulled a head, just a simple question..
lets say i want to change the headgasket.. what do i have to remove?.. search comes up with too much.. do i have to remove the valve springs or can i just remove the cams and pull the whole thing up?
Old Jul 8, 2003 | 08:53 AM
Poop111444's Avatar
Default Re: Ok i've never pulled a head, just a simple question.. (Integra_Boi)
This is what I did. I think removing the Intake manifold is optional, but i took mine off.
Removed intake manifold (lines, hoses, sensors, etc etc)
Removed valve cover
Mark timing belt teeth on cam gears
Loosen timing belt tensioner bolt (located above the crank pulley)
slide T belt off cam gears.
Remove cam cap covers
Remove cams
Remove head bolts - You need to zig zag back and forth while taking off the bolts. This is so the bolts are removed evenly. THey are on hard as F*$# your gonna need a breaker bar and a pipe.
Remove upper radiator hose
Pop the head off
You will need a manual for the torque specs.
Old Jul 8, 2003 | 08:58 AM
Farnsrocket's Avatar
Default Re: Ok i've never pulled a head, just a simple question.. (si_mekanik)
Get a Helms service manual.
Old Jul 8, 2003 | 10:21 AM
JM Performance's Avatar
Default Re: Ok i've never pulled a head, just a simple question.. (Farnsrocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Farnsrocket &raquo;</TD></TR><TR><TD CLASS="quote">Get a Helms service manual. </TD></TR></TABLE>
Old Jul 8, 2003 | 10:41 AM
shortyz's Avatar
Default Re: Ok i've never pulled a head, just a simple question.. (00SilverLS)
when u slide the timing belt off, keep tension on it and zip tie it to the motor mount so it doesnt skip around down below.
just makes putting it toghther easier.
Old Jul 8, 2003 | 10:57 AM
azboy's Avatar
Default Re: Ok i've never pulled a head, just a simple question.. (shortyz)
1. Make sure you have a Helms or repair manual of some sort.
2. set crankpully to TDC marking.
3. disconnect hose/wires/etc. that are attached to head
4. unbolt the intake manifold support bracket.
5. remove timing belt off cam gears.
6. remove cams
7. unbolt head bolts as instructed in helms or any service manual.
8. remove head along with intake manifold attached.
9. change head gasket
10. install in reverse order.
Secret Chimp
Jan 27, 2008 04:44 PM
djspecter
Dec 6, 2007 04:33 PM
usmarinedelta
Dec 4, 2006 06:25 PM
veilsides2000
Jul 4, 2005 03:08 PM
leprechaun117
Jan 31, 2003 06:45 PM
