went back to the dyno today
Old Jul 5, 2003 | 05:32 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default went back to the dyno today
went to the dyno today and expected over 500whp.made 449whp@24psi.i was having problems witht the boost controller.i made 350@15psi,430@20psi,and 449@24psi.i had a few pulls at 25psi but it made less power.i tried turning it up past 25 psi and it dropped back to 24psi.i am using a turboxs hpdbc boost controller with a .9 bar spring in a 40mm tial wastegate.it is almost like the controller doesn't want to make but abour 8psi more than the spring rate of the wastgate.a couple of months ago i tried using a .2 bar spring and it would not make more than 15psi.when it made 15 it was like the wastegate was fluttering really bad and had no power.i think i am running into the same problem now ,but at a higher boost level.i know i could just put in a larger spring,but i really don't want to change to a smaller one just for the street.
i was also having trouble with a stumble at high rpm.we changed the plugs to a brand new set of iridiums just because that was all i had except for an old used set of zex plugs.it still stumbled until i gapped them down to .025.just to see the difference,we put in the zex plugs and the ymade 6 more whp!i don't care what anyone says,the zex plugs are good!
a friend and i had been discussing the size of my air filter.it is kinda small and we thought i might be out flowing it.it is a iceman replacement filter.it is a 3.5 inlet that is 5.5" at the base,4" at the end,and 8" long.i decided to make a pull with no filter and it only made 3whp! the power fluctuates enough from run to run that the 3 hp could have had nothing to do with it.
overall,i am pretty happy.it was much hotter and more humid than last time(september).the boost was at about the same level and i think if i were toget my boost controller problem fixed,i could get 500.
Old Jul 5, 2003 | 05:38 PM
hybrid901's Avatar
Default Re: went back to the dyno today (turbotypeR)
Nice power man, what size turbo are you running? 1.8liter or 2.0?
Old Jul 5, 2003 | 05:39 PM
25 Year Member
Default Re: went back to the dyno today (hybrid901)
it is 1.8.still 81mm bore
Old Jul 5, 2003 | 05:41 PM
hybrid901's Avatar
do u have a graph?
Old Jul 5, 2003 | 05:42 PM
turbo_ef9's Avatar
good numbers... whats the setup?
Old Jul 5, 2003 | 05:45 PM
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid901 &raquo;</TD></TR><TR><TD CLASS="quote">do u have a graph?</TD></TR></TABLE>
yeha,haven't had time to scan it yet.
Old Jul 5, 2003 | 05:46 PM
25 Year Member
Default Re: went back to the dyno today (eli_vang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eli_vang &raquo;</TD></TR><TR><TD CLASS="quote">good numbers... whats the setup?</TD></TR></TABLE>
check out turborepair.com for specs.meacham.pointclark.net for videos.
Old Jul 5, 2003 | 05:50 PM
dragnGSR's Avatar
Nice #'s Danny!
Old Jul 5, 2003 | 06:00 PM
25 Year Member
Default Re: went back to the dyno today (dragnGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragnGSR &raquo;</TD></TR><TR><TD CLASS="quote">Nice #'s Danny!</TD></TR></TABLE>
thanks!who is this?
Old Jul 5, 2003 | 06:05 PM
DLB1994's Avatar
my wastegate was doing the same thing with my turboxs MBC. i got a 7psi spring and could not boost over 16-17psi on the dyno so am just getting a new wastegate with maybe a 12psi spring
Old Jul 5, 2003 | 06:16 PM
Drew Peacock's Avatar
Default Re: went back to the dyno today (DLB1994)
What gas were you using? Your sure you weren't detonating? As you made bugger all more power from 20psi -24psi.?
Still very impressive
Old Jul 5, 2003 | 06:27 PM
25 Year Member
Default Re: went back to the dyno today (turbozxi)
118 octane.i had less knock count with higher boost
Old Jul 5, 2003 | 06:35 PM
saso
Guest
Posts: n/a
those numbers arent bad, sort of close to my present setup. I have a few bag of tricks I plan, freeing up the exhaust really helped the power.
DELshaneSOL
Jul 4, 2012 01:11 PM
siis2fast
Aug 28, 2005 08:21 PM
White_EK49
May 24, 2005 09:46 PM
Chris F
May 15, 2005 07:57 AM
95gsrturbo
Dec 4, 2003 03:48 PM
