quick ? about MBC isntallation..
Old Jul 7, 2003 | 09:06 PM
turbo_ef9's Avatar
Default quick ? about MBC isntallation..
the mbc is on... but it's not letting me go to my desired boost levels.. you know how on internal WG's you can adjust the WG arm to raise and higher boost levels.. so i was wondering.. my car was boosting 8lbs already with the arm.. do you have to release the arm all the way down to a lower boost with the WG, then install the MBC or just leave the WG where it's at? does it matter at all?
Old Jul 7, 2003 | 09:07 PM
boosted92's Avatar
Default Re: quick ? about MBC isntallation.. (eli_vang)
If you want to LOWER boost fromstock you're going to have to modify the wastegate arm, otherwise you should be able to plug the controller in and go.
Mr.Death
Sep 28, 2005 08:24 AM
killa_lude
Oct 4, 2003 04:56 PM
Fatty_1775
Oct 21, 2002 12:09 PM
BigDaddyRich
Aug 30, 2002 05:34 AM
