Built D series ppl need your help!
Old Jul 8, 2003 | 05:59 AM
DsMWookie's Avatar
Default Built D series ppl need your help!
I just turbo charged my crx we rebuilt the d16a6 and put a centerforce stage2 in their motor runs great....well I have another motor in my garage I wanna build it.
Need your opinions on what I should do to get the most performance for my $$$ and keep it streetable....
I assume block guard, pistons, rods, piston rings, headgasket.....any other suggestions....recommendations of brands also needed!!! I know the good name brands just curious about your particular setups....and if theirs things you didd that you regret doing and would go back and change.
Old Jul 8, 2003 | 06:39 AM
JDMCRX's Avatar
Default Re: Built D series ppl need your help! (FMX)
Hey man im building my motor im doing the Block posting the sleeves, Weisco pistons 75.5mm, Eagle H beam rods,balanced bottom end new rings bearings oil pump u know the usual parts.
The head fully ported and polished not to much porting tho, 3angle valve job ,new seals then later the ZEX or JG cam and springs and retianers.
Im thinking of doing a block gaurd too im not sure got to do some more research
424racer
Jul 31, 2010 07:19 PM
Tad
10
Oct 11, 2004 05:16 PM
ptsaurus
Mar 20, 2004 05:33 PM
