HELP!! Not making any boost!
Old Jul 5, 2003 | 08:11 AM
arsenaldragster's Avatar
Default HELP!! Not making any boost!
Hey guys I finished the turbo install yesterday and the car started up and is idling fine. The car runs and I can hear the turbo spooling, the problem is that it dosent make any boost.. I have checked for leaks but didnt find any. I have the lower vaccum line on my tial wastegate hooked up. I dont know where to look.. I think its my wastegate. When I hook it up to the top vaccum line, at idle it is already releasing air.. is that how its supposed to work? I noticed when I was installing the wastegate there was a small gap between the "plate" and flange if i was looking at it upside down. Does it need adjusting? Because I hear that I can adjust a nut inside the wastegate.. Please help!! TIA!!!!!
Old Jul 5, 2003 | 09:01 AM
boostdB16a's Avatar
there should be no gap between the plate and flange...how many psi are you tryin to run?
Old Jul 5, 2003 | 09:13 AM
Default Re: (boostdB16a)
it only has a .3 bar spring in it right now. i was going to run that until i can get a 8 pound spring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostdB16a &raquo;</TD></TR><TR><TD CLASS="quote">there should be no gap between the plate and flange...how many psi are you tryin to run?
Thats what i thought.. is there anything i can check inside the wg to see why its like that?? is there a spring or nut that can be adjusted?? its a tial 35mm. Thanks!
Old Jul 5, 2003 | 03:08 PM
disguy409's Avatar
Default Re: (arsenaldragster)
did you get your problem fixed yet because i'm having the same problem now. the car runs fine and i can hear the turbo spooling but the boost gauge and vafc stops at zero.
Old Jul 5, 2003 | 11:02 PM
Default Re: (disguy409)
fixed it was a lowr charge pipe, check all your vaccums. ill post more later
nyjdmhatch
Jun 10, 2005 03:54 PM
tig3rxiong
Aug 4, 2004 06:40 PM
turbo se
Jun 13, 2003 11:33 AM
SIK IN DA HED
Jun 14, 2002 10:48 PM
