Boosted TEG Problems
Old Jul 6, 2003 | 01:59 PM
smuggler's Avatar
Default Boosted TEG Problems
Ive been working on this car for the last 8 months and cant figure out why the car is bogging. At 8psi it runs really good. then when I crank it up to 18-20 psi as soon as the vtec hits it boggs then it takes off. I have no idea what it is, i have been tuning all kinds with the greddy e-01 on the dyno. i have tryed every thing from sensors to the engine harness, ecu's
Old Jul 6, 2003 | 02:41 PM
Blindstuff's Avatar
Default Re: Boosted TEG Problems (smuggler)
internal setup?
Old Jul 6, 2003 | 04:58 PM
smuggler's Avatar
Default Re: Boosted TEG Problems (Blindstuff)
je pistons 8.5.1 stock bore, eagle rods, Darton sleeve, full skunk 2 valvetrain (springs,retainers,valves) Skunk2 stage 3 cams, str gears. this motor is built i put all i can into it. i just cant get it tuned right
Old Jul 6, 2003 | 06:23 PM
mamaboy's Avatar
going too rich when vtec engages....possibility....but that's my .02
Old Jul 6, 2003 | 07:16 PM
Mr. Softee's Avatar
Default Re: Boosted TEG Problems (mamaboy)
skunk stage 3 cams? holy...
Old Jul 6, 2003 | 07:19 PM
TurboJesse
Guest
Posts: n/a
Default Re: Boosted TEG Problems (94goldjungsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">skunk stage 3 cams? holy...</TD></TR></TABLE>
Old Jul 6, 2003 | 07:51 PM
crx1856's Avatar
Default Re: Boosted TEG Problems (Mpir3)
skunk 3's have too high of lift for turbo setup's. i think that's your problem.
Old Jul 6, 2003 | 07:56 PM
GEN2TEG's Avatar
You must be running the turbo cams and not the N/A cams?
Old Jul 6, 2003 | 08:09 PM
smuggler's Avatar
Default Re: (GEN2TEG)
yeah, i am runnin the turbo cams
Old Jul 6, 2003 | 09:06 PM
1bar's Avatar
Default Re: (smuggler)
nevermind goodluck wiht ur problem
Modified by 1bar at 11:06 PM 7/6/2003
Old Jul 6, 2003 | 09:42 PM
romeo619romeo's Avatar
Default Re: (1bar)
didnt kno that stage 3 skunks was turbo cams..
Old Jul 6, 2003 | 10:04 PM
smuggler's Avatar
Default Re: (romeo619romeo)
This is of the skunk2 website, I know exactlly what i'm buying for my cars.
Stage III: Stage III profiles are designed for purpose-built race engines with high-rpm capabilities only! Upgrading to Skunk2 Racing valvetrain components and extensive engine work is required for the proper functioning of these camshafts. Compression and engine flow must also be significantly increased. Stage III camshafts should be installed and tuned by professional engine builders only! Do not use oversized valves.
Turbo: Turbo profiles are designed for engines with forced induction. Aggressive lift and valve opening/closing motions allow these cams to maximize power with a minimum amount of overlap. Each profile is designed with extensive input from the top racers in the sport compact industry.
Old Jul 6, 2003 | 10:14 PM
abraunb16's Avatar
New User
What's it look like on the dyno when it bogs? Could be to much timing, fuel or not enough timing. Give more details it will better help. Later Allen
smuggler's Avatar
Default Re: (1bar)
greddy e-man, rc 460, custom rail, aem fpr, 255 intank walbro
Old Jul 6, 2003 | 10:18 PM
smuggler's Avatar
Default Re: (abraunb16)
it pulls really good before vtec hits and then when it hits vtec it just lags like there no fuel then give it a second then it pulls mad power to redline.
Old Jul 6, 2003 | 10:22 PM
abraunb16's Avatar
New User
Yeah, I just re-read and edited my post. What's the A/F look like around that spot? I don't know a lot about the eman, but can you change VTEC activation points? If so try to raise it a few hundred rpm's and see what happens. Depending on your A/F's and timing you may need to play with some setting. I know on my LS setup responded well to timing, if it would sputter up top, throw a little timing and lean the mix it fixed the problem everytime. With my LS/VTEC setup the more timing I would through the smoother things would get, up until a point of course. I would tapper off after HP gains would slow down, but playing with timing more than fuel fixed my sputter spots. I run the AEM and with modified maps, I don't know how the piggy back system will respond, it's more of a trial and error type thing that you and the dyno will have to work out. Later Allen
Don E
Feb 28, 2010 09:21 PM
kshoua
May 22, 2006 11:49 PM
S@nt0s
Mar 13, 2006 01:37 PM
PrettyLude
Nov 15, 2004 05:38 AM
blackassasin95
57
Sep 12, 2004 01:15 PM
