2 very newb questions
Old Jul 5, 2003 | 01:52 PM
ScottEK's Avatar
Default 2 very newb questions
1. Does it matter where you get a vacuum source for the wastegate actuator? Does it have to be split into the same source as your BOV?
2. If you do not use a MBC the turbo will just boost to the stock level?
Old Jul 5, 2003 | 02:03 PM
Evil EG's Avatar
Default Re: 2 very newb questions (beta13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beta13 &raquo;</TD></TR><TR><TD CLASS="quote">1. Does it matter where you get a vacuum source for the wastegate actuator? Does it have to be split into the same source as your BOV?
2. If you do not use a MBC the turbo will just boost to the stock level?</TD></TR></TABLE>
1. you tap into turbo, should have a fitting on the compress outlet that you connect the vac hose to the wastegate to.
2. you are correct it will only boost to whatever the wastegate spring is.
Old Jul 5, 2003 | 02:54 PM
ScottEK's Avatar
Default Re: 2 very newb questions (BVM)
Thanks Brandon, I actually live in the next town over from you, I've heard a lot about your teg.
I checked my turbo...
On the turbo inlet there is a detachable curved neck that has a fitting for two vacuum lines.
On the turbo outlet there is a brass bolt teflon taped right before where the first charge pipe connects. Should I use that hole or do I have to weld in a fitting on my charge pipe?
Modified by beta13 at 3:31 PM 7/6/2003
Old Jul 6, 2003 | 12:32 PM
ScottEK's Avatar
bump
almostjdmeg
Mar 10, 2008 01:00 PM
draconx
Mar 15, 2006 06:03 AM
djnikko
Nov 28, 2003 02:11 PM
TurboTeG4
Aug 27, 2003 07:46 PM
VanHonda
Jun 8, 2003 04:01 AM
