JRSC pushin' 8lbs... new injectors???
I'm gonna be running JRSC at 8lbs of boost and a Walbro 255 hp fuel pump. Will the stock injectors suffice or am I gonna need to go with larger ones???
Thanks in Advance,
Zack
Thanks in Advance,
Zack
theres and easy way to tell, go to rceng.com and use there injector calkulator. if u do need bigger ones. i might just have some rc engineering cleaned and balenced dsm 450's w/resistor box for sale.
Re: JRSC pushin' 8lbs... new injectors??? (92TEGsrSC)
An easy setup using the stock fuel supply system (ie stock fuel pump and fpr) and removing the JRSC bandaids is with the SMC and 440cc injectors.
SMC
SMC
If I remember right, 8PSI+ will require larger injectors. I remember back in the day when the 8PSI blower pulley was more popular, everyone ran the same Cartech FMU/310cc setup.
DeDonDeRosa
12-17-2002 05:24 AM
