opinions on SFP manifolds
Guest
Posts: n/a
well, since everyone says the CAMP1320 manifolds suck, and it looks like i am never gonna get that head to Tinker, and i can't afford to go baller style and get a Full-Race that is AC friendly, i am gonna have to settle for something lesser for now..... anyone had experiences with them?
Re: opinions on SFP manifolds (Boosted97Lude)
here is sfp's new manifold
they can put any flange you want on it. ac compatible. we are going to run it on our street civic soon.(motormatrix.com car)
Guest
Posts: n/a
Re: opinions on SFP manifolds (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase »</TD></TR><TR><TD CLASS="quote">suck it up, go full-race, Eat pb & j for awhile, its worth it. </TD></TR></TABLE>tell Geoff i'll taock a big *** fawking "Full-Race" sticker on my hood for a damn good deal on AC friendly mani
Re: opinions on SFP manifolds (MordecaiPSI)
I just got mine for an H23 as well - it looks better then that thing pictured above. Do a search for SFP in the prelude forum and you'll find my post w/ pictures
Re: opinions on SFP manifolds (Greyout)
SFP is fine...my friend is running one on his civic (looking for 400whp)..im running one on my dsm (looking for around 500whp) and i know of another guy running it on his civic making like 58xwhp
it gets the job done and is reasonably priced
Re: opinions on SFP manifolds (GottaLude)
SFP manifolds have come a long way and are nicer than some manifolds you'll see out there.
As for the one pictured above....did they grind down the welds or something? I don't see any welds on the collector area...??? IT sorta looks like a cast manifold, but I still see the welding on teh WG runner
Re: opinions on SFP manifolds (Paul_Vang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paul_Vang »</TD></TR><TR><TD CLASS="quote">
As for the one pictured above....did they grind down the welds or something? I don't see any welds on the collector area...??? IT sorta looks like a cast manifold, but I still see the welding on teh WG runner</TD></TR></TABLE>
I think its painted or jet-hot coated
Re: opinions on SFP manifolds (D-Man)
I got mine, the only problem with it was that they welded the wastegate pipe going to the passenger side so that if i attempted to put the wastegate on it would've have been inside the radiator fan (actually hitting the blades). my friend got one that goes to the driver side and it looks good but for some reason the welding on his looks much better. anyways instead of sending it back I got it cut and rewelded shorter so it works for now
Re: opinions on SFP manifolds (Rhman19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhman19 »</TD></TR><TR><TD CLASS="quote">why would you'll go from full-race to the sfp, unless you are curious to see what it does?</TD></TR></TABLE>
because mike upgraded to a full t4 and the full race was a t3 flange.
Re: opinions on SFP manifolds (marques4130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marques4130 »</TD></TR><TR><TD CLASS="quote">I got mine, the only problem with it was that they welded the wastegate pipe going to the passenger side so that if i attempted to put the wastegate on it would've have been inside the radiator fan (actually hitting the blades). my friend got one that goes to the driver side and it looks good but for some reason the welding on his looks much better. anyways instead of sending it back I got it cut and rewelded shorter so it works for now</TD></TR></TABLE>
did you get the race manifold? if so i think all of them might have the wastegate elbow pointing that way because they are designed to have the compressor of the turbo facing the drivers side.
this is the way my friends sfp race t3 manifold is, and another friends sfp t4 race manifold.
my friend with the t3 race manifold did have to change to a different slim fan on his fluidyne radiator though because the hks wasgate was hitting the shroud, and it still sits really close but it works out fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Man »</TD></TR><TR><TD CLASS="quote">
I think its painted or jet-hot coated</TD></TR></TABLE>
Possibly stainless steel cast? (like the InlinePro's).
Re: opinions on SFP manifolds (tony1)
i think that, too. unfortunately when i point out flaws in other things people say im an *** and other nice stuff, so i dont really comment anymore.
this looks a lot like a log mani except the flange has no bolt holes in it j/k
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">Doesn't seem like the wastegate being on the top of the collector is too good of an idea??</TD></TR></TABLE>
Bingo.
Bingo.
