DSM 450 Injector Question
Old Jul 6, 2003 | 12:28 PM
Simple's Avatar
Default DSM 450 Injector Question
91 Eagle Talon 450cc DSM injectors. will these plug in to my harness or will i need the clips that go with the injectors off the talon
Old Jul 6, 2003 | 12:33 PM
TravSi's Avatar
Default Re: DSM 450 Injector Question (Simple)
they are peak/hold injectors will plug into 4th gen honda plugs, with modification they will fit into the 5th and 6th gen plugs but you will need to run the 4th gen resitor box if you have 5th or 6th gen....just look at yur plugs and look at the plug on the injector you will see what you have to remove if you use the 5th or 6th gen plugs, also you will need integra injector seals and tehn bore them out a few mm's to get the injector to fit in the manifold, and the integra seals are used for clearence so the injector doesnt sit in to far.....good luck
Old Jul 6, 2003 | 12:39 PM
Simple's Avatar
Default Re: DSM 450 Injector Question (RexSiT3)
thanks! dont have the injectors yet, just seeing what i was getting myself into.
Old Jul 6, 2003 | 02:23 PM
MiraiZ's Avatar
you can get clips from importparts.com ...$10ea.
Old Jul 6, 2003 | 02:29 PM
dirtySOHC's's Avatar
Default Re: DSM 450 Injector Question (MiraiZ)
or go to a junk yard cut them out and put it in your pocket...........
Jdm BB6
Oct 26, 2006 06:23 AM
dpkelly
Jul 6, 2005 03:20 PM
sloweredcivic
10
Oct 13, 2004 07:22 PM
Charliehondaman
Sep 19, 2004 09:25 PM
spankaveli
Mar 8, 2003 09:05 AM
