JRSC What to do, What to do???
Old Jul 5, 2003 | 10:06 PM
92TEGsrSC's Avatar
Default JRSC What to do, What to do???
I have a JRSC I'm waiting to put on my b18c w/ 160K miles on it. I plan on pushing 8lbs of boost through the blower, and do not want to worry about blowing my engine...
I know I know-- 8lbs isn't much-- but this is my daily driven car-- I can't afford to have it off the road, and I'd rather take my time and do it right the first time than have to end up rebuilding my engine or going w/ forged internals after I put the supercharger on....
Assuming I go w/ hondata and get it tuned properly, what would you do about my block situation???
entire rebuild w/ forged???
just forged internals???
just a rebuild?
new block entirely?
sleeved block?
I don't want to spend money unnecessarily. I only plan on runnin' 8lbs of boost, so I don't htink a sleeved block is gonna be necessary-- either way... let me know what you guys think-- I really need some suggestions here...
Thanks in Advance,
Zack
Old Jul 5, 2003 | 10:13 PM
NCSTIdriver's Avatar
Default Re: JRSC What to do, What to do??? (92TEGsrSC)
If everything gets tuned properly i dont see a problem with a 160k miles. I mean do a basic tune up first, change spark plugs to a step colder, and have a compression test to make sure the motor is still healthy. The best advice I could give you is don't put yourself in a position where if something does go wrong, it will leave you without transportation. I would run the stock 6 psi pulley until you rebuild it. i would just do Stock compression Forged pistons and a set of Eagle Rods. Take the money you would to have it sleeved and put it towards a nice port and polish and multiangle valve job for your head.
Woody.
Feb 27, 2011 06:35 AM
91lsteg
Feb 5, 2008 11:42 AM
slammed00si
Mar 8, 2004 06:38 PM
B19CivicHB
Aug 19, 2002 10:34 AM
