can i see some pictures of gauge locations on ef
Old 07-05-2003, 12:05 PM
crashtest Sonny's Avatar
Default can i see some pictures of gauge locations on ef
im having hard time of finding spot to put my gauges. i only have 2, boost and EGT, and im trying to find a spot where its not too visable. in other words, i dont want it on the pillar. can i see some custom work of yours? i have integra center console but everything seems to be pretty compacted..so no room. ive seen people put em on the dash where the passenger is but i dont think you can see em. thanks.
Old 07-05-2003, 09:47 PM
Default Re: can i see some pictures of gauge locations on ef (4g_civic_si)
anyone? since when did HT been so dead..?
Old 07-05-2003, 11:55 PM
714phil's Avatar
you might get a better response in the CRX/EF civic forum.
Old 07-06-2003, 03:45 AM
Default Re: can i see some pictures of gauge locations on ef (STD ONEpointSIX)
well i figure my gauges are for boosting so i thought it should have been under FI. but ill give it a try in the crx/ef forum. thanks.
Old 07-06-2003, 12:26 PM
sporkcrx's Avatar
I had mine on the steering column. The next spot they will be is in a custom panel where the vents and clock are. You can also put them in various spots in the center console.
Old 07-06-2003, 04:37 PM
Default Re: can i see some pictures of gauge locations on ef (sporkcrx)
do you have any picture spork?
Old 07-06-2003, 05:10 PM
xci_ed6's Avatar
Here is my website, it shows how I mounted one, but you could do something similar for the other.
http://www.cardomain.com/id/krustindumm91
-Dustin
Old 07-06-2003, 06:09 PM
Default Re: can i see some pictures of gauge locations on ef (Autocratic_1st_Gen)
hey thats pretty cool. what did you use to mount that boost gauge?
Old 07-08-2003, 05:09 PM
xci_ed6's Avatar
A dremel. I just traced the right size circle onto the plastic and cut it out. I moved the hazard switch to an empty space below the cluster. It snaps in and is a little short, leaving space to run the VAFC wire out just above it.
-Dustin
Ed3joe
09-17-2017 07:24 PM
JDM_rolex
07-21-2007 09:48 AM
eghatch4sale
22
08-18-2004 04:41 AM
Quick Reply: can i see some pictures of gauge locations on ef
