Check Engine Light with UBERTEG Chip Help!!
Old Jul 5, 2003 | 08:17 AM
arsenaldragster's Avatar
Default Check Engine Light with UBERTEG Chip Help!!
Hey I was testing my set up yesterday and it was running fine, not boosting (see below), I am running 440s and the uberteg chip.. anyways my question is: Do I still need to run check valves or a missing link because after about 10 mins of driving I get a CEL and the car dies out.. I just turn the key off and restart it and the cel light goes away and I can drive fine again.. is this because I need to run a missing link? The only reason I dont think i do is since I am not making boost can I still have this problem? TIA!
Old Jul 5, 2003 | 08:41 AM
Speedz's Avatar
Default Re: Check Engine Light with UBERTEG Chip Help!! (arsenaldragster)
hey, you need to check and see what code your CEL is throwing.. also its a good idea to get in contact with the guy who you got the uberteg chip from as he may be able to help.
Old Jul 5, 2003 | 09:22 AM
Default Re: Check Engine Light with UBERTEG Chip Help!! (Speedz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedz &raquo;</TD></TR><TR><TD CLASS="quote">hey, you need to check and see what code your CEL is throwing.. also its a good idea to get in contact with the guy who you got the uberteg chip from as he may be able to help.
Will do, but do you think it has anything to do with me needing a missing link?? dosent make sense if im not making boost, right??
Old Jul 5, 2003 | 09:43 AM
TeStUdO's Avatar
you dont need a missing link with the chip. check what code you are throwing
Old Jul 5, 2003 | 10:27 AM
Mr. Softee's Avatar
Default Re: (TeStUdO)
that happened on an ecu i chipped. it was because not all the cnonections were made well enough.
Old Jul 5, 2003 | 10:28 AM
Default Re: (94goldjungsr)
connections in the ecu?
Old Jul 5, 2003 | 10:22 PM
shermanyang's Avatar
Default Re: (arsenaldragster)
wierd...should be boost just fine...better check your codes.
Old Jul 6, 2003 | 06:42 AM
Overblown-Teg's Avatar
Mine did that while the stock o2 was out while tuning with the wideband.. Make sure you didn't loose connection with your o2 sensor.
Old Jul 7, 2003 | 08:33 AM
Default Re: (Overblown-Teg)
Hey I cant pull the code.. when i shut off the car and try the jumper on the service connector and turn the car back on the acc. the cel code stays on, it dosent blink. can someone tell me the steps to make sure im trying to pull the code right. Dont I:
(1994 Integra LS B18b 2dR)
get a cel when driving
turn car off
pull out blue service connector from green boot (under the glove box)
use a paper clip and jum between the female ends of the connetor
turn car on to accessory and count the lights to get the code?
If so, im doing this right just not getting a code.. HELP!!
the car just throws a code while driving and stalls
Old Jul 7, 2003 | 09:31 AM
swrdply400mrelay's Avatar
Sounds like you're jumping fine. Is the chip installed properly? Check all your connections. Does it throw a CEL when you boost?
Old Jul 7, 2003 | 10:04 AM
Default Re: (swrdply400mrelay)
yeah, it happens when i boost or even when im at idle.. this thing got me??
Old Jul 7, 2003 | 10:08 AM
Is it possible you have a bad solder joint somewhere in the ecu??
Old Jul 7, 2003 | 10:57 AM
ill check, i really dont know what im looking for though, dont know much in the field of electronics.. someone want to post a pic of what it should and should not look like
RiipTiide67
Engine Management and Tuning
Jan 16, 2012 06:57 AM
HmgLauj69
Dec 5, 2007 09:50 AM
Extreez
Sep 22, 2007 05:43 PM
game over
Feb 19, 2005 06:15 PM
97gSrkId88
Mar 20, 2003 11:06 PM
