:: $15 manual boost controller from apolloracing.com :: anyone using this ::
Old Jul 10, 2003 | 09:50 PM
ID_ten_T's Avatar
Default :: $15 manual boost controller from apolloracing.com :: anyone using this ::
just wondering if anyone is using this. if so, care to share a review. thanks.
http://www.apolloracing.com/pr...id=66
Old Jul 10, 2003 | 11:04 PM
ScrapinSi's Avatar
Default Re: :: $15 manual boost controller from apolloracing.com :: anyone using this :: (ID_ten_T)
just go to your local grainger store & make your own.
http://pages.cthome.net/gus/mike.html
Old Jul 11, 2003 | 12:09 AM
BlueShadow's Avatar
Default Re: :: $15 manual boost controller from apolloracing.com :: anyone using this :: (ScrapinSi)
Here's another site that sells ball and spring type MBCs.
EDIT: I've also heard that the ball and spring is better than the ones using needle vlaves (or whatever they're called). The ball and spring will allow you to reach full boost sooner. And I've also heard that they are more stable and predictable then EBCs that use stepper motors or solenoids to control boost.
But that's just what I've read from people on the net.
http://www.hallmanboostcontroller.com/index.html
Old Jul 12, 2003 | 01:06 PM
ID_ten_T's Avatar
Default Re: :: $15 manual boost controller from apolloracing.com :: anyone using this :: (BlueShadow)
anyone else?
Old Jul 12, 2003 | 02:17 PM
MayhemSi's Avatar
Ball and spring boost controllers are very simple to make and require only a couple of dollars worth of parts. Search around on the internet and you will find some instructions to make several different styles. I have even seen people take two homemade ball and spring boost controllers and an electric bypass make a two stage boost controller. I personally will just stick with my profec b.
Old Jul 12, 2003 | 05:24 PM
scttydb411's Avatar
my needle valve bleeder mbc that i built works just fine. max boost quick. heck of a lot cheaper and way easier to instal than an ebc.
Old Jul 12, 2003 | 08:19 PM
rioninja's Avatar
I prefer the ball and spring style hands down over the bleeder style.
Bleeder style will make your turbo work slightly harder, increasing temp. Not much, but on my old setup it was enough to cause me problems.
cherroneballs
Mar 23, 2006 02:10 AM
hondaguyexsi
Sep 21, 2005 04:51 PM
tyrone27
Mar 26, 2005 11:40 PM
MikeExt
Dec 15, 2002 10:29 AM
Nikos
Jul 10, 2002 08:46 AM
