Motor problems after ZEX install
Old Jul 9, 2003 | 04:23 PM
VTEC-DA's Avatar
Default Motor problems after ZEX install
Car is a 00 Si with CAI, s2 manifold, dc header and tanabe exhaust. We installed a ZEX kit, purge valve and bottle heater exactly as the insturctions said, no problems. Used the 55 shot jet 3 times, two back to back and the other the next day. That was early last week. Now, his car started acting funny he said, so he removed the bottle and redid the vacuums to cancel out the ZEX box. His car is backfiring much more now, and is stumbling on acceleration. We reset the ECU, changed plugs and did a compression test. Compression was perfect across the board and the plug looked fine, just a hint of white on them. What could be wrong with the car? My guess is a fuel problem, but wouldnt backfiring indicate its too rich, and the stumbling and loss os power mean a lack of fuel? We are lost, any help is great.
Old Jul 9, 2003 | 06:42 PM
VTEC-DA's Avatar
Default Re: Motor problems after ZEX install (VTEC-DA)
Bump. Even a suggestion would be appreciated.
Old Jul 9, 2003 | 06:56 PM
cnydelSolHybrid's Avatar
did you move the timing??
Old Jul 9, 2003 | 07:10 PM
Trac226's Avatar
Default Re: Motor problems after ZEX install (cnydelSolHybrid)
I would check your vacuum lines again. Lol, should have stuck to your turbo jk
Old Jul 9, 2003 | 07:27 PM
VTEC-DA's Avatar
Default Re: Motor problems after ZEX install (Trac226)
Didnt touch the timing and the vacuums are right, its only 2 lines.
teg_95
Nov 16, 2008 02:47 PM
06rallyredsi
Honda Civic (2006 - 2015)
Dec 24, 2006 07:12 PM
ken00si
Oct 11, 2005 04:49 PM
dpw41285
Feb 18, 2005 07:56 PM
94integrablur
Apr 26, 2002 05:43 AM
