fuel rail question H22a1 what side do I splice the fmu on?
on an H22a1 what side do I splice the fmu on to the fuel rail??? I dont want to hook that thing up wrong.
Re: fuel rail question H22a1 what side do I splice the fmu on? (nigel)
On the FMU, there are 3 ports.
Top port is vacuum sources [hook this up to any vacuum source]
Side port is inlet port [ hook this port to the ORIGINAL return port from the stock FPR]
Bottom port is return port [ put the stock hose that you took out from the stock FPR to this port ]
you're basically bypassing the fuel retunr from the stock FPR to the FMU first, then back to the fuel return
HTH
stan
HTH
stan
naw what I mean...... the fuel rail, which fuel line to I cut to splice in the fmu and fuel pump?
theres fuel line on the throttlebody side and theres the fuel pressure regulator side. which one do I go to.
thanks
thanks
Re: (Flamenco-T)
ok I have everything on the right side now, but when I take it into boost at basically hits revlimiter, and leans out thats at 0psi, I am thinking I may have the fmu backwards. ok the fuel neck goes into the in on the fmu, and the out goes to the tank. is that right?
spoon23_JDizM AkA SpOoN20
04-29-2004 11:02 AM
