Block Posting or Black Guard?
Old Jul 9, 2003 | 05:33 PM
bluedelsol's Avatar
Default Block Posting or Black Guard?
i'm bulding a d16 (see sig) and was thinking of using Block posting ( http://www.muller.net/sonny/crx/engine/posted.html ) . should i do it or just get a block guard? witch would work better and wich would alow me to run higher boost?
Old Jul 9, 2003 | 05:52 PM
specie's Avatar
Default Re: Block Posting or Black Guard? (bluedelsol)
I haven't heard of anything bad with block posting...ask woofer (I believe he was the first one to introduce it to imports publicly) or Abaz on here.
Block guard, however, is controversial. Some people on here is making crazy horsepower with them, but others are having problems with them. IF you go this route, make sure you rebore/hone the cyclinder after putting the blockguard in place because it distorts the geometry.
Some say that the sleeve cracks in the middle and then work its way to the top...
Old Jul 9, 2003 | 05:55 PM
bluedelsol's Avatar
Default Re: Block Posting or Black Guard? (specie)
does anyone know how extra boost ither of these will alow me to run? (ie. 2-3psi?)
Old Jul 9, 2003 | 05:56 PM
TeStUdO's Avatar
sleeves will allow you to run a nice high boost with tuning. its a good insurance
Old Jul 10, 2003 | 01:54 PM
bluedelsol's Avatar
Default Re: (TeStUdO)
dont got the money for sleeves, i'm doing the toyota honda hybrid, turbo panda is running 18psi on stock sleeves with this setup and a block guard.
Old Jul 10, 2003 | 02:56 PM
sloppy_seconds's Avatar
Banned
i'm debating whether or not to run a block guard in my car. 120K and a maxrev kit. i see the geometry of the cylinder walls like this:
the cyclinder walls are like sky scrapers. technically, you want these things to be as strong as possible so they don't fall down and or break. but you can't make these sky scrapers too sturdy because this may make them brittle, and more prone to breaking in the wind. when the wind blows, the sky scraper must be able to "sway" a little bit so it DOESN'T break, but not too much that it'll bend the building.
the same thing occurs with cyclinder walls. they can't be too stiff and brittle, but also can't handle too much wind (boost) without bending.
so as for me doing a block gaurd, i think i'm going to do one for insurance purposes, but i'm not going to try and blow the block up. in the winter i might resleeve the block and THEN boost the ****** a lil more
Boostinb20!
Nov 28, 2008 08:30 AM
maka
Jun 7, 2004 04:14 PM
darkspector
Feb 6, 2004 09:47 AM
Rod.
Sep 12, 2003 10:51 PM
B18CHatch
Oct 18, 2001 03:06 PM
