weakest turbo b16 ever
Old Jul 9, 2003 | 02:44 PM
othick's Avatar
Default weakest turbo b16 ever
I just went to the dyno to check my a/f ratio to make sure I could drive my car around without blowing it up. Wow, my car sucks! It made 170hp to the wheels at 5psi, 29hp over when it was n/a. It was 109 degrees outside and I have basically a stock exhaust but I was thinking I could at least get 180. I plan on a lot of tuning, bigger exhaust, more boost, different compressor etc. but I just wanted to make 1 pull to check my a/f ratio before messing with anything. I'm running the v-afc hack with 370 injectors and it's pretty rich.
Old Jul 9, 2003 | 02:46 PM
Mase's Avatar
Default Re: weakest turbo b16 ever (othick)
what turbo, yeah your stock exhaust is probably whats killing it.
Old Jul 9, 2003 | 02:48 PM
Mr Hammond's Avatar
a/k/a Jomo
Don't be surprised. Most bolt on turbo kits like the drag or rev hard w/ bolt - on's are lucky if they break 200whp. My friends Si with just a Rev Hard Stage 2 with the smaller t3/to4b and Apexi N1 only layed down 190whp, but 246whp after hondata tuning.
Old Jul 9, 2003 | 02:55 PM
othick's Avatar
Default Re: weakest turbo b16 ever (Mase)
I'm running a t-3 turbo (.42/.48) but I have a .60ar compressor sitting in my carport I will be putting on soon. It's a homemade kit, drag manifold, big fmic, 2.25" downpipe.
Old Jul 9, 2003 | 03:08 PM
TeStUdO's Avatar
have you done a compression test lately??
Old Jul 9, 2003 | 03:19 PM
othick's Avatar
Default Re: (TeStUdO)
I know the engine is pretty tired (130k) but I got a n/a baseline dyno a few weeks ago on the same dyno and it made 141hp. The a/f ratio gets as rich as 10:1 at redline, it could use some tuning.
Old Jul 9, 2003 | 03:26 PM
LoSt is BlaCk's Avatar
Default Re: (othick)
dude, it could be a boost leak! check your pipes and connectors
Old Jul 9, 2003 | 03:40 PM
trbob16a's Avatar
sounds very reasonable to me. I seriously doubt it has anything to do with your engine being "tired."
Go to a 3" exhaust and bump up the boost to 10lbs, do some tuning, and it will feel like a whole new car
Old Jul 9, 2003 | 04:58 PM
MiraiZ's Avatar
don't sweat it dude...that's why people call these "projects"...it takes time to get it right. My ITR was only making like 200whp (estimated) when my turbo first went in. That's only 35whp more than my NA setup. (same boat as you) I changed the fuel computer and injectors and it jump to 261whp (measured) After I got the fuel and timing tuned...(293whp) and that is still governed because my injectors can't handle it....new injectors go in this weekend, and maybe a thicker DP end of summer...looking to do like 330~350whp...that's 150 more HP than when my turbo first went in...so be patient...work out the bugs..and tuning is the key.
Old Jul 9, 2003 | 06:00 PM
sporkcrx's Avatar
Default Re: weakest turbo b16 ever (MiraiZ)
109 degrees will hurt it too. How much does stock exhaust hurt a turbo car?
Old Jul 9, 2003 | 06:31 PM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by othick &raquo;</TD></TR><TR><TD CLASS="quote">I'm running a t-3 turbo (.42/.48) but I have a .60ar compressor sitting in my carport I will be putting on soon. It's a homemade kit, drag manifold, big fmic, 2.25" downpipe.</TD></TR></TABLE>
what do you expect? that turbo is very undersized for a b series engine, it will do alittle better with tthe 60 trim compressor though also ditch the stock exhaust
Old Jul 9, 2003 | 06:36 PM
romeo619romeo's Avatar
its your chrge pipes all equal diamater.. ? make sure the piping from the turbo to the intercooler is smaller to speed up the charged up in the intercooler.. then as big as you want after the intercooler
dester223
Nov 1, 2004 07:37 PM
tslag
Mar 29, 2004 05:36 PM
7PSiEF9ZC
Mar 24, 2004 03:22 PM
milf H U N T E R
Jul 5, 2002 05:46 PM
intekragsr
May 2, 2002 08:31 AM
