GT35R turbo
GT35R turbo
Ok well i was searching the net the other night and i asked ATP Turbo if they could get the GT35R and they emailed me back and said that Garrett didnt make a GT35R. They said Garrett only makes these. I was thinking that they did thou.
Turbine Compressor Wheel Flow Capacity
GT25R 53mm 54.4mm 240 HP
GT28R 53mm 60mm 290 HP
GT28RS 53.85mm 60mm 350 HP
GT2871R 53.85mm 71mm 400 HP
GT30R 60mm 76mm 500 HP
GT35/40R 68mm 82mm 600 HP
GT40R 77mm 88mm 700 HP
GT42R 82mm 94mm 850 HP
GT42RS 82mm 102mm 1000 HP
Re: GT35R turbo (Soon_2b_evil)
Garrett also makes some others- go to http://www.turbobygarrett.com and download the catalog- there is a GT 32, a GT30R, a GT35, a GT37, among others.
Re: GT35R turbo (SiRkid)
the gt35r (pn# 714568-0001/0002/0003) has been discontinued.
the "gt3035" is available, it uses the same 56 trim/61mm inducer gt35 compressor wheel, but is mated to the gt30 turbine wheel (ex:2.16 in:2.68)
the gt35r turbine wheel was ex:2.45 in:2.68
hope this helps.
hope this helps.
Re: GT35R turbo (CHEAPTURBOdotCOM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEAPTURBOdotCOM »</TD></TR><TR><TD CLASS="quote">the gt35r (pn# 714568-0001/0002/0003) has been discontinued.
hope this helps.</TD></TR></TABLE>
Great info!
Great info!
Re: GT35R turbo (Boostfed)
i thought the SC61 uses the GT40 compressor wheel..
are you sure it uses GT35?
Modified by Quick 200k Mile Motor at 9:44 PM 7/11/2003
No how can that be???? I've wanted that turbo so long and i have the cash in 2weeks and now i cant have it?
what about a GT3540?
There are a LOT more variations than just those, for example my GT25 is rated at 320hp, and there are also 290, 350 and 400hp versions
