Low compression numbers = fixable?
Old Jul 11, 2003 | 01:29 PM
tegasaurus's Avatar
Default Low compression numbers = fixable?
tried posting this in the integra forum, but didn't get a damn thing...
BACKGROUND INFO: ok, i did a compression test on my boosted integra the other night and all the numbers were 155-165 except the number 2 cylinder which was ~130. i noticed that my boost gauge use to read about -20/22 vac at idle, and about -22 in my old integra but now it only reads 15-18 (happend a little after i started boosting). Also, my valves sounds WAY out of wack.
my question is, can "unadjusted valves" that are way out of spec cause the slightly lower compression as well as the decrease in idle pressure? Im almost 100% certain my rings are not blown as i have 0 smoke of any color out of my exhaust and im not burning oil or anything.
-ryan
Old Jul 11, 2003 | 01:33 PM
done's Avatar
Default Re: Low compression numbers = fixable? (tegasaurus)
try doing a valve job
Old Jul 11, 2003 | 01:47 PM
tegasaurus's Avatar
Default Re: Low compression numbers = fixable? (Jordo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo &raquo;</TD></TR><TR><TD CLASS="quote">try doing a valve job</TD></TR></TABLE>
omg.... my question is not "how can i fix the compression" but "will a valve job fix it before i go through the trouble of doing it right this instant"
-ryan
Old Jul 11, 2003 | 01:52 PM
R THIS's Avatar
yes... if you do a valve adjustment it might solve your problem... it only would take one valve left a little bit open to allow air to escape and give you a faulty compression test
do a valve adjustment then check it again
you could also consider doing a leakdown test
Old Jul 11, 2003 | 01:58 PM
shermanyang's Avatar
Default Re: Low compression numbers = fixable? (R THIS)
before you try doing a valve job...try pouring a little oil into the two cylinders with low compression and doing a compression check again. if it's the valves, your psi will stay the same, if it's the rings then your compression will go up.
-sherman
Old Jul 11, 2003 | 02:09 PM
Pengo's Avatar
Default Re: Low compression numbers = fixable? (shermanyang)
yea the oil will be the first easiest to do. valve adjustment second
Old Jul 11, 2003 | 02:14 PM
FredoSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang &raquo;</TD></TR><TR><TD CLASS="quote">before you try doing a valve job...try pouring a little oil into the two cylinders with low compression and doing a compression check again. if it's the valves, your psi will stay the same, if it's the rings then your compression will go up.
-sherman</TD></TR></TABLE>
i thought if u had cracked ringlands your compression #'s wont go up either
Old Jul 11, 2003 | 02:15 PM
tegasaurus's Avatar
Default Re: Low compression numbers = fixable? (Pengo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pengo &raquo;</TD></TR><TR><TD CLASS="quote">yea the oil will be the first easiest to do. valve adjustment second</TD></TR></TABLE>
i'll be trying this... how much oil should i use? just a quick splash or what?
-ryan
Old Jul 11, 2003 | 03:02 PM
intekragsr's Avatar
1 capfull
sirt_eg
Jun 16, 2009 01:25 PM
acman1
May 21, 2007 12:06 PM
RGoose18
May 21, 2004 10:13 AM
Mr.Integra
Apr 22, 2004 07:56 PM
tegasaurus
Jul 15, 2003 09:11 AM
