making a down pipe
Old Jul 10, 2003 | 01:20 PM
DubyaAye's Avatar
Default making a down pipe
i'm about to weld my own 3" down pipe and was wondering what gauge metal shoul i use and does it matter if i mig or tig it. thanks in advance...
Old Jul 11, 2003 | 01:35 AM
DubyaAye's Avatar
Default Re: making a down pipe (DubyaAye)
does anybody know if this is the right flange for this turbo ? it looks the same but i want to make sure.
Modified by DubyaAye at 10:47 AM 7/11/2003
Old Jul 11, 2003 | 02:05 AM
ffgeon's Avatar
yessir, that is the correct flange
Old Jul 11, 2003 | 02:10 AM
paulzy's Avatar
mig or tig is fine...16 to 18 gauge is adequate
Old Jul 11, 2003 | 05:01 AM
Overblown-Teg's Avatar
Default Re: making a down pipe (Paul_Vang)
Down pipes are pretty forgiving.. if its stainless I would tig it.
Old Jul 11, 2003 | 05:12 AM
BROOD's Avatar
Default Re: making a down pipe (Overblown-Teg)
I like to tack the bends together with a MIG while mocking the downpipe up on the engine. Once everything fits to my liking I have it TIG welded. The TIG yeilds nice looking, strong welds, and smaller profile welds.
Old Jul 11, 2003 | 05:23 AM
202B's Avatar
quick question...
dubyaAye has the 5 bolt turbo and 5 bolt flange...
the turbo i purchased has a hole on the turbo...next to the compressor wheel...
probably for the internal wastegate....
can i just make my downpipe with the flange just covering the hole... ?
or
do i need to put a piece of metal to weld it closed
thanks
Old Jul 11, 2003 | 09:18 AM
Scott - 93HB Si's Avatar
Default Re: (202B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 202B &raquo;</TD></TR><TR><TD CLASS="quote">
Just cover it.
Old Jul 11, 2003 | 09:27 AM
Burke's Avatar
Banned
Default Re: (Scott - 93HB Si)
yep just cover it up and weld away. 3 in is a tight fit on there. you get pretty close to the edges, but you should be cool. i just migged mine up last week and for the hour my car ran, it worked great
good luck
later
Old Jul 11, 2003 | 08:40 PM
DubyaAye's Avatar
Default Re: (Burke)
does anybody know where to get the dp flange cheap?
Old Jul 12, 2003 | 06:48 AM
scttydb411's Avatar
Default Re: (DubyaAye)
http://www.uniquemotorsports.com and http://www.roadraceengineering.com make sell various flanges cheap.
1SlowSi
Feb 5, 2005 02:27 PM
94TurboGSR
Sep 21, 2003 10:51 PM
Andrew 825SM
Jun 20, 2002 11:59 PM
