Hondata datalogging help
Old Jul 9, 2003 | 04:39 AM
blackteg's Avatar
Default Hondata datalogging help
Could anyone help me out and send me a datalog of their car at idle for about 20 seconds and then running a bit through the gears and cruising at highway speeds? I want to compare it to what I am getting because it just seems way off to me. Thanks, oh also the car is a integra with a B16 and turbo. I know that everyones is going to be different from each other I am just trying to get an idea of what it should be around. Thanks again.
Old Jul 9, 2003 | 06:52 AM
blackteg's Avatar
Default Re: Hondata datalogging help (blackteg)
Anyone?
Old Jul 9, 2003 | 11:49 AM
blackteg's Avatar
Please?
Old Jul 9, 2003 | 12:09 PM
ladysman's Avatar
Do you have a problem?
Old Jul 9, 2003 | 12:24 PM
blackteg's Avatar
Default Re: Hondata datalogging help (ladysman)
Yes, a few I think. The O² voltage looks very low around .05-.20 most of the time. Ignition advance at idle is okay but then around 3000-4000 rpm it is between 35-40. Water temp sits right around 200, is that normal? Thats all I can remember right now. Can't remember if there was anything else.
Old Jul 9, 2003 | 12:31 PM
PureTeg420's Avatar
Here are a couple of tidbits from my datalogging. Off throttle, 02 voltage = 0, cruising is around .85-.9, WOT is around .95-.99. Water temp never goes above 85 celcuis. Ignition advance at 3500rpm and 22% throttle is 32.3
Old Jul 9, 2003 | 12:42 PM
Rob Dizzle's Avatar
Default Re: Hondata datalogging help (PureTeg420)
IM austin. He is borrowing my datalogging hondata setup. im pretty sure he has them in email form right now
Old Jul 10, 2003 | 04:32 AM
blackteg's Avatar
Default Re: Hondata datalogging help (Bob-DC2)
Thanks for the replies guys. Is Austin his user name?
Old Jul 14, 2003 | 04:38 AM
JDMCRX's Avatar
Default Re: Hondata datalogging help (CM-R)
i got some of my rex running at idle with stock cams and Big cams at idle and highway saved on file i can semd. My car was OBD 89 crx PM me
zpayne21
Engine Management and Tuning
Dec 19, 2015 12:08 PM
00ekcoupe
Jul 7, 2009 03:18 PM
T3T495GSR
Jan 1, 2006 06:17 PM
Black R
63
Feb 25, 2005 12:19 PM
B16GSR
Mar 18, 2002 04:42 AM
