Went to track last nite.. any suggestions?
Last nite i went to the track and ran 13.87@ 103.85mph.. does this time seem a little slow for that mph? my 60 ft was 2.30 i wasnt really hooking up. Any suggestions? BTW this is a stock LS, un-tuned, stock clutch, street tires, 440s and Ubertegs chip.. yes i have to say it worked out pretty well.. im impressed with his work.
Re: Went to track last nite.. any suggestions? (arsenaldragster)
try to get some drag radials, or let off the gas alittle and punch it when you feel it grab
upgrade the clutch, and if you can't get any DR, then just deflate the tires and start trying new things.... just work on that 60 ft
Re: Went to track last nite.. any suggestions? (98civicEX)
don't feel bad
last week i went to the track and got a 15.4 @ 100 w/ 2.4 60ft. and missing 2nd gear
my friend says that i need to learn how to drive a turbod car better
It's alright you just need practice. Free mods would be dropping pressure down to around 20ish psi. Try feathering the clutch off the launch instead of just droping it and either spinning or bogging. That stock clutch is not gonna like that much power put through drag raials, let alone slicks.
Not a bad time, You next purchases should be tuning, bfg's, clutch. With those mods and some more practice you will be in low 13's easy
sushibug
10
05-27-2002 09:18 AM
