IC piping size
Old Jul 10, 2003 | 11:29 AM
HuskerHybrid's Avatar
Default IC piping size
generally do you keep the size of the IC piping constant through out? or do you want it to increase in diameter right before it enters the TB? do you want it bigger going into the intercooler or after or keep it consistent? also, for 7lbs of boost is 2.25" too small? thanks
Old Jul 10, 2003 | 11:37 AM
quikB18B's Avatar
Default Re: IC piping size (HuskerHybrid)
2.25 is fine, remember bigger isnt always better. Theres a good thread on piping where art had a good theory on piping diameter. Im sure someone will post the link. Im going to run 2.25 to intercooler and then 2.5 out to t/body
Old Jul 10, 2003 | 11:38 AM
ion_four's Avatar
2" does not cause any restriction until almost 300hp, so 2.25 is perfectly fine. My only suggestion is that you step up to 2.5 someplace on the upper charge pipe so that it is close to the same size as the TB inlet (I know 2" is smaller and 2.25 might be) for optimum flow.
Rodzknight
Feb 14, 2008 08:42 AM
Sinner
Oct 13, 2003 11:30 AM
i3oricua
Mar 31, 2003 05:28 PM
