siemen deka injector help
Old Jul 9, 2003 | 02:37 PM
r7's Avatar
r7
Default siemen deka injector help
i can't get these injectors, siemen, to fit into an aem rail.. . anyone else used these injectors?
Old Jul 9, 2003 | 02:42 PM
salt's Avatar
Default Re: siemen deka injector help (r7)
use smaller o rings, I used 2 on each
Old Jul 9, 2003 | 02:44 PM
r7's Avatar
r7
Default Re: siemen deka injector help (salt)
small than the stock injector o-rings?
Old Jul 9, 2003 | 04:09 PM
Jared's Avatar
Pretty sure the siemen dekas either have to be lathed to fit a honda rail or the rail will have to be machined to accept the injector.
Old Jul 9, 2003 | 06:20 PM
Blown90hatcH's Avatar
Default Re: siemen deka injector help (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">Pretty sure the siemen dekas either have to be lathed to fit a honda rail or the rail will have to be machined to accept the injector.</TD></TR></TABLE>
Na....viren sold me some siemen dekas....which are forsale if you want them...75lbs supposedly....but anyways.....I used two sets of honda orings, about an hour and finally got them into my AEM rail that was not modified.
Jason
Old Jul 9, 2003 | 06:28 PM
VisualAutoMotoring's Avatar
Default Re: siemen deka injector help (Blown90hatcH)
i used an already machined/bored AEM fuel rail
Old Jul 9, 2003 | 06:31 PM
Default Re: siemen deka injector help (PRojectSi2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PRojectSi2 &raquo;</TD></TR><TR><TD CLASS="quote">i used an already machined/bored AEM fuel rail</TD></TR></TABLE>
With what orings?
Old Jul 9, 2003 | 06:42 PM
the ones that came w/the injectors but i took the o-ring off where the injector meets the head
Old Jul 9, 2003 | 06:54 PM
yeah so you used the Siemen orings which are way bigger.
Old Jul 9, 2003 | 06:58 PM
Jared's Avatar
I took off the oring that came with the injector where it met the head as well and used two orings where it went into the rail.
Old Jul 9, 2003 | 07:14 PM
porsche997dc2's Avatar
Here is my siemen deka injectors in stock fuel rail.
It's #3105. They flow 903cc/hr at 43.5psi. I bought them from Viren. Viren grind them down a little so they can fit the fuel rail. I double the stock o-ring them and they fit perfectly.
Old Jul 9, 2003 | 08:00 PM
earl's Avatar
Default Re: siemen deka injector help (porsche997)
You can also drill your fuel rail with a 17/32" bit and not mess with the injector. Just did one today. It helps to have a drill press, however.
Old Jul 10, 2003 | 05:22 AM
r7's Avatar
r7
Default Re: siemen deka injector help (earl)
will RC's drop in and thats it?
Old Jul 10, 2003 | 05:52 AM
Farnsrocket's Avatar
I have 75lb seimen deka's. I used the stock o-rings along with another oring from Napa to keep the stock oring from slipping down when I pressed the injector into the rail (AEM rail).
r7, will your injectors fit in your rail without o-rings?
Old Jul 10, 2003 | 05:54 AM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r7 &raquo;</TD></TR><TR><TD CLASS="quote">will RC's drop in and thats it?</TD></TR></TABLE>I think all RC's are the smaller size and that is why they are so expensive above 550 cc's.
Old Jul 10, 2003 | 06:03 AM
r7's Avatar
r7
Default Re: siemen deka injector help (Farnsrocket)
yeah they'll fit into the rail without orings
hmm, are my injectors 75lbs? they have the # 3145 on the side
Old Jul 10, 2003 | 06:10 AM
b18bturbo's Avatar
yup those are right pere the docs we have on it
P/N 3145
Static Flow Rate: 75 lb/hr @ 43.5PSI (300kPa) = 788cc/hr
Coil Resistance: 2.35 Ohms / Low Impedance (ECM driver modifications required)
Siemens low-Z injectors are able to operate at very high pressures with little or no degradation in performance.
Old Jul 10, 2003 | 06:11 AM
Old Jul 10, 2003 | 06:49 AM
turbo Si's Avatar
I have 83lb Seimen Deka's. I bought them from Tom at Camp 1320 and he sent them to me machined down so they fit in perfectly! Try machining doen the plastic a bit where it goes into the fuel rail. Then just slap on an o ring and your good to go.
Old Jul 10, 2003 | 10:37 AM
r7's Avatar
r7
Default Re: siemen deka injector help (b18bturbo)
so if i ordered 550cc injectors, these are the wrong ones?
Old Jul 10, 2003 | 12:49 PM
r7's Avatar
r7
anyone want to buy these injectors? =o
Old Jul 10, 2003 | 01:44 PM
http://www.cprracing.com/injectors.htm
Old Jul 10, 2003 | 02:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by porsche997 &raquo;</TD></TR><TR><TD CLASS="quote">Here is my siemen deka injectors in stock fuel rail.
It's #3105. They flow 903cc/hr at 43.5psi. I bought them from Viren. Viren grind them down a little so they can fit the fuel rail. I double the stock o-ring them and they fit perfectly.</TD></TR></TABLE>
The sheet that you got with them from Viren said that they flowed 95lbish at 43.5 psi?
Old Jul 10, 2003 | 02:40 PM
r7's Avatar
r7
where do i find out what the #'s on the side mean?
Old Jul 10, 2003 | 02:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">
The sheet that you got with them from Viren said that they flowed 95lbish at 43.5 psi?</TD></TR></TABLE>
from this website:racetronix.com
