this one is for the engine builders & boost gurus
Old Jul 9, 2003 | 06:40 PM
APEX i GSR's Avatar
Default this one is for the engine builders & boost gurus
Which piston have you had the best luck with
JE, Arias, CP ?
just curious
bought a set of 9:1 JE .020 overbore and i'm second thinking my purchase
are these good enough in a sleeved block?
or should i look at another brand
plan on boosting up to 15 psi tuned with Hondata
any suggestions Art, Viren, John, Tony
Old Jul 9, 2003 | 06:46 PM
VisualAutoMotoring's Avatar
Default Re: this one is for the engine builders & boost gurus (APEX i GSR)
ummm hmmm well what bore is your sleeves at???
i've had good experience on JE
dont know about Arias but all the old skool people use to run them
I've heard nothing but great reviews on CP
alot of people are running higher compression pistons like 10.0:1 for daily driving purposes i guess but with good tuning, you should have no problem running 10.0:1
9.0:1 is lil low compression but works fine...that's what i'm running on my B16a
Old Jul 9, 2003 | 06:48 PM
ExospeedAMcrx's Avatar
you shouldnt have to worry about those 3 brands.. they are top notch.
Good enough for many race cars.. good enough for your street car.
Old Jul 9, 2003 | 07:17 PM
ghettocrxsi's Avatar
Default Re: this one is for the engine builders & boost gurus (exospeedAMcrx)
Out of those 3 brands I personally have bad experience with Arias pistons. My buddy Art bought a set stock bore for his h23 prelude with a GE sleeved block. He broke the motor in as per spec from Ge and his machinist. Gets the car on the dyno and is at 7psi with hondata getting tuned and the ring land cracks and the top of the piston pops off and gets jammed in a valve.
EDIT: I forgot to say on the dyno A/f was at 12:0 all the way through boost. Had a perfectly flat torque curve the piston just malfunctioned and the top separated from the ring lands
So he buys a new piston from arias same thing happens on cylinder #2 this time. He is giving up after spending over 5,000 dollars on his turbo and motor build to put a stock jdm h22 in his car so he doesn't have to worry about those pistons any more.
He said he is done with Fi and the problems he has had with his pistons. I have Je 9.0:1 in my d16z6 crx and they are great
Je
Old Jul 9, 2003 | 08:41 PM
tony1's Avatar
Default Re: this one is for the engine builders & boost gurus (ghettocrxsi)
I'd be willing to bet there was another problem with that car. I've used JE and arias tons of times and they're both good pistons. We run arias in our race car and they handle the power we make, so i'm sure they're good enough for any street honda! I really don't have any reason to recommend any one of those brands over another. I'd stay away from srp for high hp, but all the ones you mentioned will work fine. Pistons don't break themselves, bad tuneups break pistons!
Old Jul 9, 2003 | 09:17 PM
Default Re: this one is for the engine builders & boost gurus (tony1)
I agree with Tony. BTW, is the Jotech team going to be at the Vegas event?
I'd like to stop by.. but im shy man.. hehe
Old Jul 9, 2003 | 09:28 PM
tony1's Avatar
Well, we're undergoing some MAJOR changes to the car right now and we plan to be ready by vegas, but you know how that goes! We should be there. Stop by and say hi, i'm not mean
Old Jul 9, 2003 | 09:34 PM
rOby's Avatar
ross are nice too
the jotech car makes no where near as much hp as my neighbors apc/autozone sponsored/pep boys tunned civic
Old Jul 9, 2003 | 10:48 PM
Foozball26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Stop by and say hi, i'm not mean </TD></TR></TABLE>
Yup tonys cool just yell vin diesel or tony he answers to both
Old Jul 10, 2003 | 01:20 AM
sgT's Avatar
sgT
Default Re: this one is for the engine builders & boost gurus (Foozball26)
JE is great, as long as they arent SRP.
Old Jul 10, 2003 | 05:54 AM
Dublocivic's Avatar
Wiseco pistons are good too.
Old Jul 10, 2003 | 02:31 PM
APEX i GSR's Avatar
i just wanted to make sure i didn't make a bad buy
Old Jul 10, 2003 | 02:57 PM
boosted_zc's Avatar
Default Re: this one is for the engine builders & boost gurus (sgT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">JE is great, as long as they arent SRP.</TD></TR></TABLE> Damn , you guys are scaring me with the SRP bashing. I got SRP's with Eagle rods for my boosted setup. Hope those bastards hold up cause i'm out of money.
Old Jul 10, 2003 | 04:10 PM
paulzy's Avatar
Default Re: this one is for the engine builders & boost gurus (boosted_zc)
I've experienced JE and Wiseco's...They are both very good, but I like the JE's just because when you have both in your hand, the JE feels like a stouter piston(it's just in my head though)
Oh, and Tony, I hope you don't bite
Old Jul 10, 2003 | 04:15 PM
BrokenVtec's Avatar
Default Re: this one is for the engine builders & boost gurus (Paul_Vang)
i run Arias pistons and i have used JE's in the past....like everyone else said....all 3 brands are good.... if i were you i would try the CP's.....everyone seems to love those pistons
Old Jul 10, 2003 | 04:19 PM
Boostfed's Avatar
New User
If the A/F was straight at 12.0:1 then you mustve had some timing issues or a dead injector but that would lead me to belive it would be lean. The Arias are good pistons so there definately had to be some problemwith that build or tune.
Oh I have experiences with Endyn/Wiseco 3 sets 81.5mm, 84.5mm and 85mm. The current motor has 84mm JE because the block was already bored to them at the shop so I took them too. I like the quality of them. I was very Impressed with ROSS pistons too I saw some CP also nice
Old Jul 10, 2003 | 05:37 PM
falcongsr's Avatar
What is this crap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Foozball26 &raquo;</TD></TR><TR><TD CLASS="quote">
Yup tonys cool just yell vin diesel or tony he answers to both </TD></TR></TABLE>
damn...beat me to it
Old Jul 10, 2003 | 05:38 PM
tony1's Avatar
Default Re: this one is for the engine builders & boost gurus (falconGSR)
Old Jul 10, 2003 | 08:48 PM
Flamenco-T's Avatar
just don't get tony on his bad hair day, other than that, he's fine
stan
Old Jul 10, 2003 | 09:02 PM
Pelican's Avatar
I like that. Kinda like the NRA quasi-slogan
Pistons don't kill motors. You kill motors
Old Jul 11, 2003 | 01:40 AM
Foozball26's Avatar
Default Re: this one is for the engine builders & boost gurus (Flamenco-T)
lol
just stop the sale and production of rogaine and tony will never have a bad hair day
Old Jul 11, 2003 | 04:41 AM
shermanyang's Avatar
Ross and CP gets my
SRP gets my
methos713
21
Jun 14, 2007 10:56 PM
RA062424
Oct 20, 2004 10:46 AM
H22Prelude
Oct 25, 2002 06:08 AM
civictypenos
Oct 3, 2002 03:36 PM
Si_leeper
Nov 17, 2001 08:22 AM
