some overheating issues
Old Jul 11, 2003 | 03:59 PM
tegasaurus's Avatar
Default some overheating issues
After i installed my turbo in may, the car started to over heat and my car has "hyper blinkers" lol. although these things may seem unrelated i think they are.
first, i replaced the radiator and it still overheats, now im thinking its either the thermostat or the fan switch, fan switch because the hyper blinkers started (blown fuse under hood, right?) which may also mean i blew the fan relay fuse.
When the car warms, and its tiem for the fans to come on, should there be a little noise comming from the passenger side of the bay?
Also, if the upper radiator hose gets warm (this is after about 15 minutes of idling) and the lower stays the same, that's the waterpump, or is that the thermostat?
-ryan
Old Jul 11, 2003 | 04:43 PM
intekragsr's Avatar
Default Re: some overheating issues (tegasaurus)
Do you fans kick on?
do you have bubbles or over flowing radiator bottle?
Is it overheating at idle? On the freeway?
Smoke from exhaust?
Old Jul 11, 2003 | 05:45 PM
B_1_8_hatch's Avatar
i had the same problem. mine was bubbles and over flowing radiator bottle.
what could it be. it only happened the first time i got on it after the turbo install. haven't driven it again to see if it will do it again. my fan does come on though.
Old Jul 11, 2003 | 07:18 PM
Rpc07's Avatar
Default Re: some overheating issues (93hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hb &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem. mine was bubbles and over flowing radiator bottle.
what could it be. it only happened the first time i got on it after the turbo install. haven't driven it again to see if it will do it again. my fan does come on though.</TD></TR></TABLE>
[radio-transmission]Tower one, this is aero 216, this post has been hijacked.[/radio-transmission]
Old Jul 11, 2003 | 07:20 PM
tegasaurus's Avatar
Default Re: some overheating issues (Rpc07)
My car can be driven for about 45 minutes, boosted every 10 or 15 minutes and it wont overheat (this is in the middle of the day). But after that ~45 minutes, when i stop at a light and sit there for about 20 seconds or so, then take off, it'll overheat.
There is no smoke of any color coming from the engine bay or exhaust.
the fans kick on, im just not sure when. I know that when i was bleeding the coolany again this afternoon, after about 10 minutes of idling, i heard a click/motor noise near the battery but the fans didn't come on... is that the relay?
-ryan
JH4DB858
Jan 10, 2012 07:32 PM
G. Man
Classic Hondas
13
Sep 2, 2011 10:36 AM
esean93
11
Jul 29, 2008 05:33 PM
civic4g63
19
Jun 11, 2007 09:41 AM
Mattyg2
Jun 1, 2004 02:46 PM
