turbo gsr vafc hack question
Old Jul 10, 2003 | 10:39 PM
2001teggsr's Avatar
Default turbo gsr vafc hack question
I ve tried search bu cant find the correct settings for vafc hack on gsr with drag turbo can anyone help find a link to this?
Old Jul 10, 2003 | 11:02 PM
Type-GS-R-Turbo's Avatar
Default Re: turbo gsr vafc hack question (2001teggsr)
If you're using your stock map sensor, goto Etc.>Sensor Type, set In-06 Out-15 Then lean out your A/F mixture in wide throttle to -7 from 4000-8000 Rpm
If you're running a 3 bar map, do the same except set In-14
This works in my car. Built GS-R, Drag turbo, running 11 psi so far.
You might get a Barometric pressure sensor light. Don't worry about it.
Read my thread about this topic.
https://honda-tech.com/zerothread?id=531705
Slow_import
11
Jan 29, 2010 05:26 PM
broadway
Mar 17, 2007 09:04 PM
reditr
Jun 8, 2003 04:01 AM
TuRbOgSr818
Oct 5, 2002 08:47 AM
forced-d16
Sep 22, 2002 09:11 PM
