Valve springs A6 or Z6 what the difference
Re: Valve springs A6 or Z6 what the difference (JDMCRX)
I know the compressed height is different, because the Z6 has Vtec, and the A6 doesnt.
If you are thinking of useing the A6 springs in the Z6 head, i wouldnt recommend this at all.I could almost garuntee you that you will see some spring coil bind and then.........................................BOOM! !!
HTH
Brian
HTH
Brian
I am not sure on the exact spring height.
I am sure you can use the retainers, but you may be better off to match the retainers up with the same brand name of spring.
Brian
Brian
civic00sir.
03-19-2010 09:59 AM
Hella_Fresh
03-13-2007 01:37 AM
GersWorkz
03-27-2006 07:30 PM
