uberteg chip? fuel....
Old Aug 22, 2003 | 09:44 PM
mattcalica's Avatar
Default uberteg chip? fuel....
okay, i just purchased a uberteg chip from thedropshop.tv...i searced and found that you still have to run a afc...what exactly is the chip? does it just allow adjusted timing maps or can you adjust the fuel curve as well? what does this chip do? i want to run in on my turbo b16a...
Old Aug 22, 2003 | 10:07 PM
94TurboGSR's Avatar
Default Re: uberteg chip? fuel.... (mattcalica)
Old Aug 22, 2003 | 10:19 PM
Joseph Davis's Avatar
Define "just," and what is your setup?
Old Aug 22, 2003 | 10:24 PM
mattcalica's Avatar
um, just as in today....and i have a stock b16a...t3/t4e turbo...pr3 ecu....dsm 450's i have a 255 pump coming in...so what does this chip do?
Old Aug 22, 2003 | 10:29 PM
Default Re: (mattcalica)
It's boost code, but it's not tuned specifically for your engine, thus the AFC.
Uh, PR3 ecu?
PR3 = OBD0, I don't think that's going to work for you.
Modified by J. Davis at 12:02 PM 8/23/2003
Old Aug 22, 2003 | 11:09 PM
mattcalica's Avatar
nope, they said that it works with pr4s...which is the same thing except without vtec
Old Aug 22, 2003 | 11:40 PM
Smashback's Avatar
hehehe...yeah
Old Aug 22, 2003 | 11:51 PM
mattcalica's Avatar
umm, okay...why is everyone getting smart with me...i just asked a question, because obviously i didnt know the answer. the site says it is compatable with the pr4 ecu...it is obd0 and for a dohc motor just like the pr3, that is why i say it is similar. can i just get a straight-foward answer?
Old Aug 23, 2003 | 01:04 AM
omahaturbocivic's Avatar
It only works with obd1 ecus so if its an obd1 pr4 and your car is configured for obd1 then yes it will work, otherwise if its an obd0 pr4 (which I assume it would have to be since you are currently runnin an obd0 pr3)then it wont work and you got some work ahead of you if you plan on running an uberchip.
Old Aug 23, 2003 | 08:05 AM
Default Re: (omahaturbocivic)
OBD0 != OBD1
OBD0 PR4 != OBD1 PR4 (there are two, you know)
Neither PR4 more than half resembles the PR3/PW0 B16A1 ECUs. It's a wierd *** unique piece.
dohc4life
Oct 14, 2010 08:38 PM
90turbointegra
Engine Management and Tuning
Aug 12, 2009 11:20 PM
b18bcrxhf
Dec 9, 2006 07:25 PM
dkrex001
11
Sep 12, 2006 11:03 AM
mattcalica
Aug 23, 2003 04:38 PM
