Big Problems w/Turbo B20!!!!
Old Aug 20, 2003 | 12:26 PM
RnR Racing's Avatar
Default Big Problems w/Turbo B20!!!!
Alright guys I am having big problems with my B20 turbo Integra. This is what is does. As soon as it hits boost past 4psi it falls on it's face and won't rev up. You can punch the gas and the rpm just start to fall lower and lower.
It won't go anywhere and now it can't be driven.
It will rev up in nuetral just fine, but as soon as there is a load on the engine in won't go anywhere. If you engage the clutch you can get it to go a little bit, but not much.
Please give me any suggestions or experience you guys have. It seems like a IC pipe is just blowing off and not enabling the car to rev. I have pressure tested the system and changed the plugs. Here is the set up
94 Integra
B20B
FMU, 320's
FMIC
8psi
external fuel pump
t3
The car use to run alright and now it has started doing this to where it is not driveable. Any help or suggestions would eb great as my wife wants me to just pull the turbo off, but I don't want it to come to that.
Old Aug 20, 2003 | 12:34 PM
boosted92's Avatar
Default Re: Big Problems w/Turbo B20!!!! (RnR Racing)
I don't think it's your IC pipe blowing off, because the car would still run. What disc are you using in the FMU and whats your base fuel pressure?
Old Aug 20, 2003 | 12:40 PM
ladysman's Avatar
Default Re: Big Problems w/Turbo B20!!!! (boosted92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote">I don't think it's your IC pipe blowing off, because the car would still run. What disc are you using in the FMU and whats your base fuel pressure?</TD></TR></TABLE>
I was going to say it is running WAY rich.
Old Aug 20, 2003 | 12:46 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Big Problems w/Turbo B20!!!! (ladysman)
I second the running way rich... what FMU disc are you using? What color are your plugs?
Blaze
Old Aug 20, 2003 | 01:37 PM
paulzy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RnR Racing &raquo;</TD></TR><TR><TD CLASS="quote">
FMU, 320's
that's your problem right there. I bet you still have a 12:1 disc in there
Old Aug 20, 2003 | 01:57 PM
psileepR's Avatar
New User
Default Re: Big Problems w/Turbo B20!!!! (Paul_Vang)
check your plugs... we can all guess that its gonna be black ... and probably fouled.
i 3rd it being RICH.
Old Aug 20, 2003 | 02:42 PM
cokex's Avatar
I've seen this prob. before .. once it was a gas tank full of crud. replaced it and everything was good ..
other time different car it was the tps ..
so take off your fuel filter and see if any crud is in there .. if not then check the tps ..
sleeponef
Dec 17, 2010 12:45 PM
95 RED CIVIC
May 3, 2006 12:21 PM
bambam
Feb 2, 2005 11:23 AM
The G2 Racer
Nov 6, 2002 03:27 AM
yusoslo
Oct 22, 2002 01:46 PM
