hondat s200b prob. help!!!!!!!
Old Aug 20, 2003 | 05:36 PM
integrated civic's Avatar
Default hondata s200b prob. help!!!!!!!
ok, ive got a s200b with all the features except for g-sensor
the problem i am having is that i cant datalog in romeditor,i can datalog fine in hondalogger,my romulator seems to be working fine on uploading a map,car starts,no ck eng. light and steady light on s200,i have tried differnt com ports on the datalog side with no luck. the settings have been checked including disabling fifo. i am running windows xp for an os on my laptop with two usb to serial adapters. one adapter for romulator and the other for the s200. what else do i check
Modified by integrated civic at 2:47 AM 8/21/2003
Modified by integrated civic at 6:51 AM 8/21/2003
Old Aug 20, 2003 | 06:22 PM
ladysman's Avatar
Default Re: hondata s200b prob. help!!!!!!! (integrated civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrated civic &raquo;</TD></TR><TR><TD CLASS="quote">ok, ive got a s200b with all the features except for g-sensor
Modified by integrated civic at 2:47 AM 8/21/2003</TD></TR></TABLE>
You can only datalog in 1 program at a time. It took me a few times to figure that on my own. If you can datalog in Hondalogger, your connection seems OK. Just close out that program and try leaving just the Rom Editor open.
HTH
Old Aug 20, 2003 | 07:57 PM
LSBeast's Avatar
Default Re: hondata s200b prob. help!!!!!!! (ladysman)
hondalogger is closed when trying to datalog in romeditor-
integrated civic
Old Aug 21, 2003 | 03:37 AM
ttt
Old Aug 21, 2003 | 04:49 AM
ladysman's Avatar
Default Re: hondata s200b prob. help!!!!!!! (LSBeast)
Sounds like you have a problem with the port selection. Have you tried having 1 serial port and I USB?
Old Aug 21, 2003 | 05:15 AM
i don't have any serials on my laptop,just 2 usbs and i printer port. could i run a 25 pin to db9serial port adapter for the romulator "instead of using two usbs" if so what port settings would i set up for this 25 pin port since its Lpt1?
Old Aug 21, 2003 | 06:36 AM
tony1's Avatar
I have the same problem and i haven't figured it out either I used someone elses computer and software and it worked, so it's either my laptop or the software I have.
Old Aug 21, 2003 | 07:20 AM
Default Re: hondata s200b prob. help!!!!!!! (tony1)
hey tony,on the laptop that you are having problems with, what operating systems are you using and how old is your laptop and what brand? what laptop fixed it and what operating systems did it have?
Old Aug 21, 2003 | 12:02 PM
someone help please
Old Aug 21, 2003 | 07:19 PM
tony?vapor trail?gruvy tune?rocket? anyone have any suggestions
Old Aug 22, 2003 | 07:21 AM
maddog20's Avatar
try using any other operating system besides XP,XT or NT they are not DOS based.
Try that
Old Aug 22, 2003 | 02:26 PM
Default Re: hondata s200b prob. help!!!!!!! (maddog20)
problem solved thanks anyways
rotascircuit
Mar 24, 2008 05:22 PM
racereaper7
Oct 20, 2006 07:27 AM
ShinRutia
Jun 24, 2006 02:04 PM
Slammin585
May 24, 2006 09:54 PM
