ITBs interest?
Old Aug 21, 2003 | 07:49 AM
Tinker219's Avatar
Default ITBs interest?
Im guaging interest on producing a universal(GSR, ITR, B16A) set of ITBs for boosted and NA applications...Price is not even an issue right now as we are still in EARLY prototype stages.
Glass impregnated Nylon *may* be the material used, this will keep the cost down tremendously(tooling will suck, but hey, what tooling doesnt?),will help with the weight department and thermal properties. Get this, Custom colors will be easy to mess with
So...who would be interested? Right now, B series Vtecs only...but as always, the more interest, the more products...
Old Aug 21, 2003 | 08:00 AM
FOrSfEd's Avatar
Default Re: ITBs interest? (Tinker219)
You know I'm down, sounds like it might be pretty straight.
Lee
Old Aug 21, 2003 | 08:15 AM
Swift's Avatar
I must say that you peaked my interest.
Old Aug 21, 2003 | 08:16 AM
Stroker
Guest
Posts: n/a
Default Re: ITBs interest? (Swift)
I'm all about it im looking for some right now
Old Aug 21, 2003 | 08:28 AM
simple4012's Avatar
New User
the main problem with itb's is the problem of getting an accurate map signal. with boost the problem would be ten fold
Old Aug 21, 2003 | 08:43 AM
Joseph Davis's Avatar
Default Re: ITBs interest? (simple4012)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simple4012 &raquo;</TD></TR><TR><TD CLASS="quote">the main problem with itb's is the problem of getting an accurate map signal. with boost the problem would be ten fold</TD></TR></TABLE>
(The whole issue of vacuum canisters aside)
No, the problem with ITBs is in NA form, in a speed density setup - anything over 25% throttle is almost identical to atmospheric pressure. You have to set your MAP pressure scalars very close together near WOT/atm and tune like hell to avoid flat spots and driveability problems. For NA ITB SD (Speed Density aka MAP sensor equipped) cars, utilizing one of the freeware Honda ECU tuning apps, it is easier to replace the MAP with the MAF from an 86-89 GM 5.0, as it is a linear output 0-5v device. Tuning is now flow dependant and not pressure - yay!
Boost alleviates that problem, as 3/4 of your throttle event is no longer acted upon as if it were WOT, with regards to MAP input. Feel free to retain the MAP sensor in boosted ITB setups.
I have a couple sets of 954RR ITBs sitting on my shelf. Cut stock intake flanges and radiator hose are the order of the day when it comes to mounting these and tuning runner length. I give props to tinker for fancy multicolored plastics, which will look bling and you kids will go crazy over - but here in the trailerpark we don't give a f*ck what things look like.
Old Aug 21, 2003 | 08:58 AM
Tinker219's Avatar
Not with a bolt-on plenum
Old Aug 21, 2003 | 09:11 AM
Eh?
That's creating a mental image that defeats the purpose of ITBs in my mind.
And, have you played with the idea of camming the ITB throttle pulley so that the last half of it's rotation is the last 25% of gas pedal travel? It would be a little more driveable, and throttling the pedal for boost would be a bit easier.
Old Aug 21, 2003 | 09:43 AM
95hbMatt's Avatar
Default Re: ITBs interest? (J. Davis)
hmmm..I could modify an ITR ITB's to fit my LS motor!
Old Aug 21, 2003 | 09:46 AM
Full-Race Geoff's Avatar
you cant accurately base the map signal pre-butterfly
Old Aug 21, 2003 | 10:43 AM
redlineb18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">Eh?
And, have you played with the idea of camming the ITB throttle pulley so that the last half of it's rotation is the last 25% of gas pedal travel? It would be a little more driveable, and throttling the pedal for boost would be a bit easier.</TD></TR></TABLE>
Ill toy with it, makes perfect sense. Kind of opposite of a bow and arrow if Im understanding what you are saying...
And for the map, could I not just tap into each TB(after the plate)with a vac line, and connect them all to the map sensor? just a thought, I cant see why it wouldnt work accurately(maybe thats my downfall )
*edit* haha, my brother is still online, this is Cody that posted up above
Old Aug 21, 2003 | 12:53 PM
JaeOne3345's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">
Not with a bolt-on plenum </TD></TR></TABLE>
not quite. you want to take vacuum somewhere inbetween the head and the butterflies though for a good signal. with a bolt on plenum, you could use it for MAF, but not map. with map, u still need to source vacuum at a point where the intake charge has passed the butterflies already.
if you had itb's with a plenum on the end, and took signal from the plenum/airbox, that'd be the same as a conventional honda intake manifold, and taking a vacuum reading from the aem intake thats attached to it. wouldn't suffice.
you could take vacuum source from all 4 runners and run them to a properly sized canister.
Old Aug 21, 2003 | 01:23 PM
liam821's Avatar
25 Year Member
Default Re: ITBs interest? (JaeOne3345)
Some pictures of the Magnus Motorsports manifold for a 4g63.
Just eyeball the runners. No ITB's in this manifold, however im guessing this is something what tinker wants to do. Bolt a big plenum to some ITB's with volocity stacks. The magnus has the volocity stacks inside the plenum.
There is a few more pictures here:
http://www.roadraceengineering...ifold/
thanks,
liam
Old Aug 21, 2003 | 01:44 PM
Tinker219's Avatar
Default Re: ITBs interest? (redlineb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlineb18 &raquo;</TD></TR><TR><TD CLASS="quote">
And for the map, could I not just tap into each TB(after the plate)with a vac line, and connect them all to the map sensor? </TD></TR></TABLE>
I ment post-butterfly. Itd be simple to do some nipple fittings w/Ts going to a Vac log where the Map sensor would get its reading. This is what I had planned on doing.
As for the Magnus IM, that is basically what its going to look like , but with the TBs on each stack. From what I have gathered, this is the BEST way to make power, boost or not. Am I mistaken with this? Because if I am, the project is mute, and Ill just make a badass thermoplastic Velocity Stack manifold
Old Aug 21, 2003 | 01:56 PM
Fac3Man's Avatar
Default Re: ITBs interest? (liam821)
Those velocity stacks just create turbulance in the plenum, they dont help accelerate the airflow. You could make a small radius in the transtion from plenum to runner to increase velocity.
Old Aug 21, 2003 | 02:17 PM
lazerus's Avatar
Default Re: ITBs interest? (Fac3Man)
i know the streetglow 2jz drag cars run a plennum with velocity stacks on the inside....
Old Aug 21, 2003 | 02:37 PM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fac3Man &raquo;</TD></TR><TR><TD CLASS="quote">Those velocity stacks just create turbulance in the plenum, they dont help accelerate the airflow. You could make a small radius in the transtion from plenum to runner to increase velocity.
That is what the golden eagle manifold is like. They have a small radius that transitions plenum to runner. And then each runner is tapered.
liam
Old Aug 21, 2003 | 02:42 PM
lsvtecvx's Avatar
Default Re: ITBs interest? (lazerus)
Extreme's Talon also ran with Itbs, dont know if they still do though.
Old Aug 21, 2003 | 02:53 PM
LSiTurbo's Avatar
Default Re: ITBs interest? (lsvtecvx)
We just installed one of thoe Magnus tirds on a DSM, man is that thing poor craftsmanship. It is just like the one above. The vacuum ports on the back have weld slag all in them.
Old Aug 21, 2003 | 03:35 PM
GSRswapandslow
Guest
Posts: n/a
hopefully i will be the first person boosting with the 954 setup from J.Davis
i have a manifold ready to bastardize...and a turbo setup...ready to go on...
damn chipping ecus takes up way too much time...There needs to be more ROB time
Old Aug 21, 2003 | 03:42 PM
TeStUdO's Avatar
id be really intrested in this especially when you show a prototype. keep us updated
Old Aug 21, 2003 | 09:16 PM
integra_gsr98's Avatar
Default Re: (TeStUdO)
I've put the magnus intake mani on two DSMs now and we've had nothing but good luck with them. If tapping out the ports on the bottom of the mani are difficult then there are bigger issues at hand.
I'd love to see a magnus style intake mani for hondas that is in that same price range.
Old Aug 21, 2003 | 09:32 PM
tony1's Avatar
I've always heard and read that velocity stacks raised off the floor of the plenum is the best way...
Old Aug 21, 2003 | 09:34 PM
xJ.SLOTHx's Avatar
Default Re: ITBs interest? (tony1)
they've been doin this with nissans for a while now...
Old Aug 21, 2003 | 10:36 PM
GSRswapandslow
Guest
Posts: n/a
GTiR
M3
both use ITB's and a plenum
