Oil pan :mad:
Old Aug 21, 2003 | 01:48 AM
swlabhot's Avatar
Default Oil pan :mad:
There seems to be a constant leak at my oil pan Thing is, when the car is stationary I don't see any oil coming from the oil return tap but oil just seems to be around the bottom of the pan so I think it may be the oil pan gasket that is letting out oil when the car is moving...
As everyone knows the pains of getting the pan to seal properly having taken it off for the oil return weld, I just don't want the hassle of taking the whole pan off and changing the gasket and then realising that it still leaks. So should I just put some JB weld around the seal?? Will this hold up or should I remove it and change the gasket?
The last time I checked the oil level I was quite shocked that it dropped quite considerably. I'd topped it up to just above the max level and having done about 300miles it dropped dwon to about half, between the min and max level There is no signs that the motor is burning any oil
Old Aug 21, 2003 | 04:10 AM
DaveF's Avatar
Default Re: Oil pan :mad: (swlabhot)
you didnt overtighten the pan did you? sometimes it will push the gasket out and cause it to leak.
Old Aug 21, 2003 | 04:27 AM
swlabhot's Avatar
Default Re: Oil pan :mad: (2.2Lcivic)
I hope not. Sometimes its hard to tell how just how tight is tight. How much should they be torqued?
Old Aug 21, 2003 | 04:31 AM
1fstevo's Avatar
New User
Oil pan gasket owned me for a while before...
After five or six gaskets finally figured out the stock pan is warped.
Old Aug 21, 2003 | 04:38 AM
DaveF's Avatar
Default Re: Oil pan :mad: (Evo Hybrid)
7ft/lbs (i think, this is off the top of my head)
Uljima
Jun 3, 2015 06:17 AM
uEDarkShadow
Jul 13, 2006 07:02 PM
projectej8
11
Apr 3, 2005 02:45 PM
LAKER HATER
May 21, 2004 07:51 AM
Pinhead
Jun 9, 2002 01:53 PM
