Turbosmart Manual Boost Controller Question...
Old Aug 22, 2003 | 11:36 PM
Drumwurks's Avatar
Default Turbosmart Manual Boost Controller Question...
I'm using a Turbosmart MBC on my mitsubishi turbo.
The stock wastegate can is set to 5.5psi. With the MBC, I have it set to 7psi. I'm getting some nasty boost spike (as much as 9-10 psi sometimes).
Vaccum lines run from the turbo compressor outlet source on the turbo, go through about one inch of vaccum line into the MBC, and then through about 11 inches to the nipple on the wastegate actuator can.
I'm looking for ways to either eliminate, or reduce the spike... as it's really annoying, and causing my motor to go a bit lean at higher boost. (ecu untuned over 8psi)
Any help would be great, thanks!
Old Aug 23, 2003 | 08:37 AM
Drumwurks's Avatar
Default Re: Turbosmart Manual Boost Controller Question... (Drumwurks)
Bump!
Anyone??
Any thoughts?
Old Aug 24, 2003 | 09:29 AM
Pengo's Avatar
plug the compressor nipple and run boost/vac source from intake mani
superhatchbackbros
Jun 30, 2007 09:17 AM
fracas
May 4, 2006 07:07 AM
Brycen
Oct 6, 2005 03:02 AM
White_Comet_Of_Akagi
May 19, 2004 05:18 AM
jovial111
Dec 15, 2003 04:39 PM
