*Can i Swap 2nd o2 sensor in place of Primary? ASAP *
Like topic says, last night we began phase 1 of turbo install and when taking off the header redlinegsr accidently unplugged 3 wires and the 4th(green) one ripped in half(o2 is a **** to get off ). My primary sollution is to switch the secondary o2 sensor in it's place, but will it work properly? Did a search and no luck. If not can the wire be soldered? Or do i need to find a new or used one today? Please help
btw the car is a 97 LS, with obd1 conversion
Thanks in advance
Thanks in advance
Re: *Can i Swap 2nd o2 sensor in place of Primary? ASAP * (quikB18B)
the wire can be soldered because i did that same mistake. as for swapping it with the secondary..i don't think that'll work but it won't hurt to try though
i have to so called map of where the wires go into the O2 sensor harness. the cut wire can be soldered back. let me go to my car and get and call me later so u wont need to buy another sensor. those ****'s are expensive.
Re: *Can i Swap 2nd o2 sensor in place of Primary? ASAP * (b18b98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b98 »</TD></TR><TR><TD CLASS="quote">the wire can be soldered because i did that same mistake. as for swapping it with the secondary..i don't think that'll work but it won't hurt to try though</TD></TR></TABLE>
THEY'RE THE SAME THING!!!...
Re: *Can i Swap 2nd o2 sensor in place of Primary? ASAP * (Flamenco-T)
Thanks guy, thans stan, i though i was going to have to spend some more $ going as im officially broke until the 1st.... Stan check your pm, are you still coming over today? About 4:00-4:30
Iggy...if it doesnt work then Ill help you on the money part. it was an accident but it was me that broke it. So r u leaving work a little early
BlueShadow
12-01-2005 08:10 PM
slwazgsr
10-17-2002 06:53 PM
