Straight power yo fuel pump?
Old Aug 22, 2003 | 01:11 AM
B18C1_T's Avatar
Default Straight power yo fuel pump?
is it possible to run striaght constant power from battery to fuel pump? if so would this increase flow?
Old Aug 22, 2003 | 01:52 AM
rjardy's Avatar
Default Re: Straight power yo fuel pump? (B18C1_T)
12 volts is 12 volts..........
No, but why would you want to?
as long as its a good power source, it will be fine. You want more flow, get a bigger pump.
Rob
Old Aug 22, 2003 | 02:51 AM
lazerus's Avatar
Default Re: Straight power yo fuel pump? (rjardy)
use a relay inbetween the battery and pump, and turn the relay on with the ignition.
The only way you would get more flow, is if the stock wiring is not able to provide full amperage to the pump under full boost/fuel pressure/flow.
boost16awd
10
May 19, 2017 10:21 AM
thatcivic96
Aug 24, 2014 04:20 PM
turbogsrbaby
Apr 6, 2013 12:04 PM
jvans04
Jul 24, 2005 04:49 PM
