need help runing vacum tube into cabin on 95 grs.....
i am installing a boost gauge in my 95 gsr and cant find a place to run the vacum line...... can someone please tell me ware to run the line.....
thanks
chris
thanks
chris
Re: need help runing vacum tube into cabin on 95 grs..... (71 mgb)
theres a hole right above the gas pedal under the dash pok out the grommet and use that hole. i did mine last night
Re: need help runing vacum tube into cabin on 95 grs..... (nextelbuddy)
thats where i did mine too , i put thwe line in wire loom thought before i fed it thru just to make sure nothing under there cut or sliced the line when feeding it up to the gauge.
K i l l a B e e.
10-29-2007 08:56 AM
TurboBumblBee
06-04-2003 07:32 AM
