what kind of numbers should i expect for a built b16
i just put in a b16 with je 9:5.1 pistons,eagle rods,ge 84mm sleeves, 3 angle valve job head,gsr cams,portflow springs/retainers,hondata s200,rc 550 injectors. what kind of whp can i expect with a revhard 2c kit?
Re: what kind of numbers should i expect for a built b16 (HXMan)
Damn, this is a pet peeve of mine, but I can't stand it. You don't have 9:5.1 pistons. If you had 9:5.1 pistons your motor would have 1.76:1 compression. It's 9.5:1
I would expect you are gonna reach the limit of the 550s, depending on the turbo. The engine setup should be able to make good power.
Re: what kind of numbers should i expect for a built b16 (BlueHatch00)
we built a 00 si pistons,rods,valves,retainers,blah,blah,blah, with hondata, and a greddy kit and it made 328whp at 15psi. he just recently upgraded to a prcision sc 61, rev hard manifold, and hks wastegate and he made 230 at 7psi. all on pump gas
