The Hack Causing High Fuel Pressure?
Old Aug 20, 2003 | 08:56 AM
SOFLSOL's Avatar
Default The Hack Causing High Fuel Pressure?
Why would the hack cause fuel pressure to rise? When I installed my smc500 with NA, stock injectors, and a high flow pump. It caused the car to flood at 0% correction. Even with stock pump. Why would pressure rise as soon as the map is controlled by the hack?
Old Aug 20, 2003 | 01:13 PM
SOFLSOL's Avatar
Default Re: The Hack Causing High Fuel Pressure? (SOFLSOL)
Nobody? *bump*
Old Aug 20, 2003 | 01:15 PM
Code Blue's Avatar
i think the fuel pressure is high because the stock fuel pressure regulator does not have a big enough fuel return orifice, correct me if im wrong. i believe switching to an aem would help
Old Aug 20, 2003 | 02:07 PM
2000vsm's Avatar
hahhahha
hello, right now i just drove my stock civic with smc500 at 0% correction. runs fine.. you got problem buddy.
Old Aug 20, 2003 | 02:38 PM
psileepR's Avatar
New User
Default Re: The Hack Causing High Fuel Pressure? (2000vsm)
he has a high flow pump... i believe if he doesnt use all that fuel ... say wiht a turbo the return isnt able to keep up with all that extra fuel...
BobbyRodriguez
Aug 18, 2012 12:00 AM
X2BOARD
Apr 8, 2004 05:16 AM
tolowhb
Apr 6, 2004 06:42 PM
zseeanz
Jan 28, 2004 07:58 PM
HybridCoupe
Jul 6, 2002 03:48 PM
