hondata and IAC question
Old Aug 22, 2003 | 07:51 PM
stinker504's Avatar
Default hondata and IAC question
Is there a problem with installing a hondata system with an IAC that has 3 wires comming out of it? I just read this https://honda-tech.com/zerothread?id=599148 and I want some sort of confirmation. I was told by secret services that installed a p28 and a hondata system on my 6gen accord would be no problem.
Old Aug 22, 2003 | 09:00 PM
stinker504's Avatar
Help, anyone???
Old Aug 23, 2003 | 08:06 AM
stinker504's Avatar
bump
Old Aug 23, 2003 | 08:15 AM
Joseph Davis's Avatar
Default Re: (stinker504)
Only done this on OBD2a to OBD1 harness, here are my notes:
On the OBD2a connector put a jumper across terminals A12 and A14 so that they connect to the A9 terminal on the OBD1 side. The third wire is A13 on the OBD2a connector and it goes to A23 on the OBD1 side.
If you have OBD2b car, I can probably advise, but, well, I'm ******* lazy and would rather not lift a finger unless completely neccesary.
Old Aug 23, 2003 | 08:28 AM
stinker504's Avatar
Default Re: (J. Davis)
Is this OBDIIA or OBDIIB ??
Old Aug 23, 2003 | 08:32 AM
Goddamn you, OBD2B. How dare you make me work
Old Aug 23, 2003 | 08:46 AM
stinker504's Avatar
If you read this thread https://honda-tech.com/zerothread?id=599148 I hope the installer just didn't know how to wire this setup.
Old Aug 23, 2003 | 09:38 AM
If I'm understanding this correctly, I have no OBD2a/b wiring diagrams in front of me (anyone with a Helms, scan and email pls pls pls?) the two pins you worry with are OBD2b B6 and B23. Switch those two in the harness, and all should work.
I have a few emails off, hope to know for sure tonight.
Old Aug 23, 2003 | 04:30 PM
stinker504's Avatar
Thanks a lot for your help. I hope you get a write up soon for this. I'm suppose to get everything done within 3 weeks.
Old Aug 23, 2003 | 05:14 PM
lazerus's Avatar
i play no part in this thread, but thanks j. davis for the info
Old Aug 23, 2003 | 09:50 PM
stinker504's Avatar
I'm just trying to get my car boosted so here is another bump.
Old Aug 23, 2003 | 11:13 PM
stinker504's Avatar
Anybody with a diagram of OBDIIB please post!!!!
Old Aug 23, 2003 | 11:32 PM
OBD2 Helms ECU wiring diagrams needed, pls. I have neither test vehicle nor information to go on right now.
Old Aug 24, 2003 | 01:28 AM
ash.zero's Avatar
j.davis, this is the ecu pin layout for obd2b (6 gen accord)...will this help?
thanks in advance!
edit: oh damn, i just realized that i'm missing 1 more page! i guess that's the page with last connector which would include IAC?
Modified by ash.zero at 10:39 AM 8/24/2003
Old Aug 24, 2003 | 07:48 AM
stinker504's Avatar
come on guys.......one more picture and I'll have the hondata figured out.
Old Aug 24, 2003 | 06:20 PM
ash.zero's Avatar
stinker, you might want to try other forums?
Old Aug 24, 2003 | 06:45 PM
stinker504's Avatar
I'm asking all major 6gen accord forums but they all have that diagram. Most of them all want the vtec wire and don't bother scanning the other page....I'm working on it
Old Aug 24, 2003 | 07:14 PM
stinker504's Avatar
Okay I give up.....I'm going to honda tomorrow and asking them to photo copy me that page.
Old Aug 24, 2003 | 07:26 PM
youngkow's Avatar
Check this site out : http://www.pgmfi.org/phorum/re...t=371
There is a lot of info on this site.
Old Aug 24, 2003 | 07:33 PM
stinker504's Avatar
thanks I'll check that out too.
93delslow315
May 27, 2010 09:23 PM
fasterthanueg
Jan 29, 2008 01:39 PM
danieljweaver
Mar 21, 2007 08:29 PM
Pinhead
Mar 13, 2002 10:00 PM
